Originally Posted by Zadok
Any info on ugrading the front suspension on a Road King?
Looking for some experience with possibly upgraded
and lowered as well as just upgraded. Just figure
it might be worth the time to upgrade while doing
some front end work.
Thanks.
Harley-Davidson
Put some American GUTS into those wimpy Japanese forks on your Harley! (No, they aren't made in America...) You don't weigh 120 pounds, and that front suspension on your bike can't hold you up! If you are tired of the bouncing, wallowing, bottoming, chattering, wobbling of your stock forks, then TRAXXION DYNAMICS has the CURE!
"What's wrong with my stock forks?" you ask...Your stock Showa forks have a "damper rod" in them to control the movement of the wheel. This style of fork is used for cheap production parts. Trying to compare a damper rod fork to a cartridge fork is like trying to compare a carburetor to fuel injection. There simply is no comparison. The damper rod fork is the cheapest, poorest performing system of damping, and has been around on Harleys for so long nobody seems to be able to remember.
Looking to improve how your Harley handles? Click Here for more detailed specifications on the AK-20 Axxion Cartridge Kit.
Damper Rod Upgrade
The next problem is your stock fork springs. The stock springs are so weak and wimpy that they can't even hold the bike up; never mind that they are completely unable to hold you up when you get on it, or you take a passenger along. Just pick your bike up off the side stand sometime and watch it collapse before you even get on!
The result is a fork that bottoms over large bumps, wallows in high speed turns, dives dramatically when you pull the brake, cups and tears up your tires, and leaves you generally feeling uncomfortable and lacking confidence in the feel of your bike.
The "cartridge fork" came along about 20 years ago in sport bikes, and since has been highly refined. The kit you see in these photos is absolutely STATE OF THE ART. It was introduced in February of 2005. It is EXTERNALLY ADJUSTABLE to suit your personal preferences. It comes with springs matched to your weight and your intended use. And best of all it WORKS!
The AK-20 Axxion Cartridge Kit DRAMATICALLY transforms ill handling Harleys with Showa forks (basically any bike since about 1988). Immediately you will feel a smooth, controlled ride. The bike will not dive under aggressive or panic braking. You will have a confident feel even in high speed sweeping turns. Your tire wear will improve dramatically. Your pegs and floorboards will stop dragging the ground in turns. You will have great control and stability at low speeds, such as moving through a parking lot. Even your passenger will notice the difference! Overall, you won't recognize your own bike!!!
This kit is Made In The USA with pride in Woodstock, Georgia by skilled machinists and craftsmen. You cannot buy a better working set of forks anywhere, at any price. We guarantee it. The price for the AK-20 Kit is $1149.95 and Installation is $150. For more information on the AK-20 Axxion Cartridge Kit Click Here.
