Cycle Gear
Old 04-12-2007, 02:47 PM   #1 (permalink)
pkclark1 is on a distinguished road
Wheel Removal in BFE... How?
So lets say I'm out in BFE along the ALCAN Highway and I get a flat on my '98 RK. How in the Hell am I gonna get the wheel off to patch the tire? Is there a field expedient, SurvivorMan center stand I need to learn how to make out of empty beer cans I collect from the ditch? Lay the million pound King on his side and hope not to beat the crap out of the bags? Is there a collapsible stand that comes with me? What gives? And yes, I ask specifically about the ALCAN for trip planning reasons.
pkclark1 is offline   Reply With Quote
Old 04-12-2007, 06:03 PM   #2 (permalink)
Premium octane member
TXCHOP's Avatar
Dont have to take wheel off for these..It will get you to a local dealer if you have an air source as well...
TTS tuned by Jd's Cycleworks
Black Boarzilla
Wood's TW9FG cams
Old 04-12-2007, 07:02 PM   #3 (permalink)
repeat offender
Flyin Brian's Avatar
Flyin Brian is on a distinguished road
Do you have tubeless tires? Then I would use a plug kit like Chop suggested. Otherwise, you're going to have to access the tube which more than likely means you've got to pull the wheel. There must be a way to do it. Depending on what's available where you need it to be, I would think you *might* be able to put something under the jiffy stand to support the foot and then lean the bike over on the stand and get the back end up in the air and then slide some boards or rocks under the frame.
Since you bring up "survivorman", I would bet a way to do it if you absolutely had no other solution would be to get something solid for the frame to rest on like boards or rocks, and then you could dig a hole under the rear tire to get enough clearance to remove the wheel. I know it sounds crazy but it would work if you had no other way around it.
You're still gonna need some pretty sturdy tire irons too...
2006 FLHXI Street Glide
GMR 98" R&R CAST HEADS
R&R 615/585 cams - S&S Gear Drive
roller rockers
HP INC 55mmTB SERT
Choose Revolution Performance and prepare to be piston slapped!
This message has been sent to you using recycled electrons exclusively. Please do not discard them after use, send them along and help conserve these irreplaceable sub-atomic resources for future generations.
Flyin Brian is offline   Reply With Quote
Old 04-12-2007, 09:27 PM   #4 (permalink)
mooooving out!
route66paul's Avatar
This is what fix a flat foam is for. It can get you to a garage. dealers don't like it, but you will.
43%er
Bi-polar and loving it!!
Bi-polar and hating it!!
95" w/ KB pistons (flattops)
HQ575 cams
Atwood's Road Warrior Heads
HPI bored throttle body
.030 head gasket
SuperTrapp Supermeg 2in1
"43" points cover
TRW rear mount
obligatory Baisley Spring
Just sayin..........
Old 04-12-2007, 10:15 PM   #5 (permalink)
11963 is on a distinguished road
Cool
yur in bfe(alsaka) an ya have a laptop an no tools ????????????? wtf ride hard cb
11963 is offline   Reply With Quote
Old 04-13-2007, 09:39 AM   #6 (permalink)
Barbsnewrider is on a distinguished road
Without a doubt, if you put fix-a-flat in your tire-- tell the service writer, and hand the MECHANIC $10 and apologize. Before he gets the goo all over him.
I'm pretty sure a center stand isnt gonna do you any good without also diggin a hole under the tire, havin the tire irons, and a big ol wrench or possibly two, maybe a mallet cause-did the last guy in there anti-sieze your axle? Rusty axles suck.
Barbsnewrider is offline   Reply With Quote
Old 04-13-2007, 11:14 AM   #7 (permalink)
I have spoked rims with tubes. Hadn't thought of digging a hole, that just doesn't sound like a goood time. Not that fixin' flats are. There HAS to be a "good" way to do this.
Old 04-13-2007, 11:16 AM   #8 (permalink)
Uhhhhh....no. Sitting on my a$$ watching the Sopranos, trying to figure this out
Old 04-13-2007, 11:18 AM   #9 (permalink)
I was thinking fix-a-flat not-so-fix tubed tires
Old 04-14-2007, 11:32 AM   #10 (permalink)
Has anyone tried using a small, scissor jack for this? As in the type that come in most car spare tire kits. I've found several available, but all weigh more than I'd like to carry along with me (10+ pounds). Is there a lightweight, alloy version of these available?
Old 04-14-2007, 12:22 PM   #11 (permalink)
I saw a version of one of these that came apart and fit in a saddlebag. www.cyclelifts.com
Old 04-14-2007, 12:31 PM   #12 (permalink)
mooooving out!
They use it in bicycle tires (with tubes). this way, all of the goo is inside of the tube, that is even better. If it gets you to a garage or a motel, it has done its job.
43%er
HQ575 cams
.030 head gasket
"43" points cover
TRW rear mount
Old 04-14-2007, 01:38 PM   #13 (permalink)
Murf2 is on a distinguished road
When I had to fix a flat on the road. I took out the battery, it was not a sealed battery, took off the bags and laid it on it's side. I then pulled the wheel out the bottom. It was a major pain. This was with a tube tire. I've run tubeless for the last 10 yrs. and have had much more fun. Good Luck!
Later, Murf
Murf2 is offline   Reply With Quote
Old 04-14-2007, 10:52 PM   #14 (permalink)
DILLIGAF
berserker's Avatar
I change all my own tires so not a problem. First rear was changed by PO, and I am guessinf little lite on the antiseize, and was a PIA.
I carry progressive tire repair kit with CO. Thinking about making one of the ones with spark plug hollowed out and a hose on it to pump up the tire.
I have seen a front tire changed with just a car jack on the forks. Might get a passerby to help or use peice of wood. Since I have front and rear engine guards, push comes to shove I would lay it down.
But with tubeless, not much you are going to do with out plug kit. I carry alot, but not a spare tire.
Old 04-15-2007, 12:07 AM   #15 (permalink)
Doing time, behind bars!
The_Snowman's Avatar
The_Snowman is on a distinguished road
Arrow Bikernet.com
EMERGENCY TUBELESS TIRE REPAIR
2004 Softail NON Standard
Deuce Rear Wheel 17" x 4.5"
Fatboy Front Wheel 17" x 3.5"
D&D Fatcat 2-1 Exhaust
ThunderMax with Autotune
Arnotts Air Suspension
The_Snowman is offline   Reply With Quote
