I'm with you. Ness tends to go over the top for me but I like this bike except for the fender.
Its the new Victory Freedom 106ci engine and it has all the normal Ness Victory aftermarket parts, mirrors, headlight, wheels with matching rotors and pulley , scalloped covers, open pulley,. Some of the new cool stuff, digital info center, inverted Forks RAKED TREES, 6 piston CUSTOM calipers (they match the tear drop mirrors)Custom frame, rear fender, 5.5 gallon stretched tank, front fender, , Rad hand and forward controls and on and on!!
The rear wheel is a 20 with a 280mm tire on a 10.5 wheel and the front a 23 but the rear wheel is offset way to the left by the brake rotor a cool look.
The same exact bike can be had with the S&S 124.
In a few month the Highliner will be released which is a full 8-up Chopper.
You made your bed. Now lay in it or change the sheets!
2006 Victory Jackpot. The highlights;
Ness K&N intake
Victory Stage 1 Shotgun Exhaust
Kewlmetal Pro Stock 45 degree Rake Kit
Kewlmetal Bleed Feed Air Ride
Ness Cross Wheels, 21x2.5 front, 18x10.5 rear
and a whole BUNCH of other stuff
