Headlight mounting problems
I have a '02 Road King and it seems like every time you need to do something with the front end, the headlight needs to come off. It is attached by 7 screws that screw into 7 rubber mounted nuts. These nuts last about 2 cycles of off/on. Then they shred or the nuts tear loose from the rubber.
Is there a alternative mounting procedure or aftermarket replacement mounting solution/fix for this problem?
I have my bike serviced every 2,500 miles and the 5,000 and 10,000 service interval removes the headlight resulting in at least two of these fragile nuts being damaged. I would dearly love to replace them with a more dependable mounting system. I assume they are rubber mounted to shock mount the headlight.
