Oil Change Question ??? Jiffy Stand or Jack Stand ??? : V-Twin Forum: Harley Davidson Forums
Old 11-22-2006, 03:12 PM   #1 (permalink)
Hog Wild wants to know Dino or Syn?
I've seen posts where people change all 3 holes with bike on jiffy stand and also seen posts where people change all 3 holes while it's on a jack stand. I did mine the other day and pretty much did it on the jiffy stand because when it was up on the jack stand (Craftsman) the stand is in the way of getting the oil and tranny drain plugs out. What is the proper way to do it, jiffy stand or jack stand ? I have an 03 Road King, Thanks !!!
Life Is Cheap
It's The Accessories
That Will Kill Ya !!!
Hog Wild is offline   Reply With Quote Quick reply to this message
Old 11-22-2006, 03:25 PM   #2 (permalink)
mtmtrspt wants to know Dino or Syn?
The stand has nadda to with the oil change objective and what it's all about. The point is to perform it in a manner that drains as much of the oil out of the cases as possible. To do this, the bike needs to be constrained "straight up". Do what works for you.
Mule Team
2006 Vivid Black FLHTCUI
95 Cu.In., Andrews 26a Cams
Big Boyz Heads, VPC Clutch
2003 Vivid Black (Gold Key) FLHRCI - gone
>>>dirty deeds done dirt cheap<<<
mtmtrspt is offline   Reply With Quote Quick reply to this message
Old 11-22-2006, 03:36 PM   #3 (permalink)
Ironbutt
MilesToGo's Avatar
I do the oil change and primary on the kick stand. The bike needs to be on the lift to do the tranny, otherwise a lot of the fluid won't drain.
Current bikes in the stable:
2009 Street Glide
2003 Heritage Softail Classic
Old 11-22-2006, 03:54 PM   #4 (permalink)
msocko3's Avatar
I do all 3 on the jiffy stand, I do however get on the bike and hold it straight up off the stand when I'm doing the transmission so I can get as much out as I can. Doing them on the jack just makes to much of a mess, I put the bike on the jack for the rest of the service once all 3 holes have been plugged and the oil filter has been changed.
2012 GL1800 Hannigan.
Old 11-22-2006, 04:20 PM   #5 (permalink)
Ground Hawg
twinV's Avatar
twinV wants to know Dino or Syn?
Jiffy stand man.
03 98" FLHRI
73 100" shovel
Life is twisted, full of surprising turns
twinV is offline   Reply With Quote Quick reply to this message
Old 11-22-2006, 04:38 PM   #6 (permalink)
2006flhtci's Avatar
2006flhtci wants to know Dino or Syn?
After oil and primary, I put the lift under the frame so only one arm is under the very front under the floorboards, just to get it level and stable, for the trans.
2012 FLTRX
Rinehart 2 into 1| Ness Big Sucker A/C | Heritage Bars | 15" Cee Bailey TRSSC | Sancho's Wings
2006flhtci is offline   Reply With Quote Quick reply to this message
Old 11-22-2006, 05:32 PM   #7 (permalink)
ASA Lives
Ultra89Rider's Avatar
Ultra89Rider wants to know Dino or Syn?
Oik Change
Attachment 36884
I have a "Ride Off" stand. It is mounted on the front of the frame by the floorboards and engine guard. It holds the bike in an upright position.
la'Hom Ho'neH jorDe' vestai-VamPyr
wa'DIch, IKRV Hurgh HaP, Ring of Fire Fleet
Order of the Bat'LetH
"lIgh tlhab"
(Ride Free)
Ultra89Rider is offline   Reply With Quote Quick reply to this message
Old 11-22-2006, 05:34 PM   #8 (permalink)
"Jane you ignorant slut!"
ceraaa42's Avatar
ceraaa42 wants to know Dino or Syn?
Be sure to read your owners manual. During the refilling procedure I think the engine and primary are to be on the jiffy stand and the trans with the bike level. Doing it in the improper manner and you will either have each quanity over or under full.
Chrsi
Candy red sunglow
103"
SE255 cams
SE Air cleaner
Fatcat Quiet baffle
Bagger brace
43 member
ceraaa42 is offline   Reply With Quote Quick reply to this message
Old 11-22-2006, 08:18 PM   #9 (permalink)
greenboot wants to know Dino or Syn?
Or you can just pour in the recommended amount.
Tom
greenboot is offline   Reply With Quote Quick reply to this message
Old 11-22-2006, 08:25 PM   #10 (permalink)
y2kflhr's Avatar
y2kflhr wants to know Dino or Syn?
when I did it on the red craftsman lift, I took some siding, bent it in a v shape, then put a short board inbetween the supports to hold it up, point the v to the catch bin and done, no mess. I now have an aluminum craftsman jack and its more of a pain, and I gave the old lift to a buddy with my makeshift stuff, so I still have to figure something out.
y2kflhr is offline   Reply With Quote Quick reply to this message
Old 11-22-2006, 09:10 PM   #11 (permalink)
Retired
rkt88403's Avatar
rkt88403 wants to know Dino or Syn?
Jiffy stand man.
Bill H. UAW LOCAL 652 Retired
'04 Impact Blue FXSTI.
Stage1,fork brace,mini tach,windshield.
I wanna die young at a very old age.
rkt88403 is offline   Reply With Quote Quick reply to this message
Old 11-23-2006, 09:11 AM   #12 (permalink)
Krayven Sumhead wants to know Dino or Syn?
Here's a link to JP'sLastStand. Lifts either the front wheel or back wheel off the ground, giving the bike a three-point stance which is level and very stable.
Great for storing the bike on in the winter months also. Everything is stainless steel. Lots easier than trying to work on a bike that is tipping and tilting and no floor jack to interfere with your work. Had mine since '03.
http://www.jpslaststand.com/
I bought the one for a tourer, but it works just as well on the Sportster also.
Krayven Sumhead is offline   Reply With Quote Quick reply to this message
