Love and hate Screaming Eagle heavy clutch spring : V-Twin Forum: Harley Davidson Forums
Old 11-11-2012, 10:45 AM   #1 (permalink)
alexlivetoride's Avatar
alexlivetoride wants to know Dino or Syn?
Installed a SE heavy clutch spring, love the action, definitely less slippage. However it is about 30% heavier, have been searching an ez clutch for a 6-speed, couldn't find anything. Any workaround? Thanks!
alexlivetoride is offline   Reply With Quote Quick reply to this message
Old 11-11-2012, 11:10 AM   #2 (permalink)
not sober all the time
Uncle Salty is reading this now saying WTF is this? Uncle Salty is reading this now saying WTF is this?
Several options to choose. Some go with a VPC (Variable Pressure Clutch) that uses centrifugal force to put more pressure on the discs. I went with a Rivera Pro clutch that has more surface area and a lighter pull than the stock clutch. That's the only one I've used. It works well with my mild 95" (100/100) build. I rarely even need to adjust it so I assume that means it's not wearing very fast. It definitely holds the power.
Uncle Salty is online now   Reply With Quote Quick reply to this message
Old 11-11-2012, 03:34 PM   #3 (permalink)
msocko3's Avatar
I'm running a product called the ClutchWiz on my 06 Ultra with a 120" HQ build, I'm using the Energy One extra plate clutch plus the AIM billet pressure plate along with the 480 lb AIM clutch spring. With the ClutchWiz I'm not getting any detectable clutch slippage and my clutch pull is butter smooth and easy plus its cheaper than a VPC.
2012 GL1800 Hannigan.
Old 11-11-2012, 03:57 PM   #4 (permalink)
Ironbutt
MilesToGo's Avatar
Thanks for the info. I'm going to have to try this on my Street Gide. Ever since i did the engine build and went to the SE clutch spring i dread getting stuck in city traffic due to the heavy pull.
Current bikes in the stable:
2009 Street Glide
2003 Heritage Softail Classic
Old 11-11-2012, 08:58 PM   #5 (permalink)
Awesome! I don't wanna spend $300 for a VPC centrifugal clutch spring, Clutchwiz $138 sounds reasonable.
Old 11-16-2012, 05:30 AM   #6 (permalink)
msocko3's Avatar
I've been quite happy with mine, the guy who manufactures it is a stand up guy who puts customer service 1st. I've also run them on both my dad and my Trike, I had one in my Trike with Wood 555 cams and SE spring while pulling a trailer through VT and NH never had a single issue.
Old 11-16-2012, 01:09 PM   #7 (permalink)
I saw this on ebay the other day, said it will work on 00-12, can anyone confirm? As far as I know 5 and 6 speeds are different. Thanks!
http://www.ebay.com/itm/Burly-Brand-...fdc67b&vxp=mtr
Old 11-16-2012, 02:23 PM   #8 (permalink)
B17-117 fits a lot of models. Check yours here.
Old 11-16-2012, 02:34 PM   #9 (permalink)
Thanks! I have checked earlier, it fits my Dyna.
My only concern is 5 and 6 speeds are different, how can one size fit all? Unless the Burly one fits both, I have emailed tech support, you know Friday, nearly no response lol.
Old 11-16-2012, 03:30 PM   #10 (permalink)
Ironbutt
MilesToGo's Avatar
There's about $100 difference in price between the Clutch Wiz and this Burly product. The down side to the cheaper (Burly) product is i have to remove my exhaust which makes this more than a 30 min job. I also have to purchase new exhaust gaskets and clutch cover gasket. The Burly would still be cheaper in the long run, even considering the new gaskets but definitely much more of a pain to install. At this point, i'm still going with the Clutch Wiz just to avoid the extra labor.
2009 Street Glide
Old 11-16-2012, 05:20 PM   #11 (permalink)
sprinkman wants to know Dino or Syn?
Clutch Wiz is great easy install. Could you do both the wiz and burly and reduce the clutch pull even more?
sprinkman is offline   Reply With Quote Quick reply to this message
Old 11-16-2012, 05:46 PM   #12 (permalink)
webco2 wants to know Dino or Syn?
In a word, Yes.
webco2 is offline   Reply With Quote Quick reply to this message
Old 11-16-2012, 11:14 PM   #13 (permalink)
It will feel like hydraulic clutch I bet
Originally Posted by webco2 View Post
In a word, Yes.
Old 11-17-2012, 06:57 AM   #14 (permalink)
msocko3's Avatar
There have been people installing them in their CVO bikes to lessen the hydraulic clutch pull when a stiffer spring has been installed.
Old 11-18-2012, 04:40 PM   #15 (permalink)
pjvedder10 wants to know Dino or Syn?
I have an AIM VPC and have been very happy. Also, SE makes a VPC now too worth checking out.
pjvedder10 is offline   Reply With Quote Quick reply to this message
