120R Slight Problem : V-Twin Forum: Harley Davidson Forums
Old 04-04-2011, 02:02 PM   #1 (permalink)
vanslam's Avatar
vanslam wants to know Dino or Syn?
120R Slight Problem
Okay so I keep burning tire and popping wheelies at will. Rolling the throttle and blowing by my friends. More recent trrips to the gas station. Enjoying the hell out of riding my 120r powered Ultra so much my other bike sits there gathering dust.
Anyone else with a 120r experiencing the same or other issues?
vanslam is offline   Reply With Quote Quick reply to this message
Old 04-04-2011, 02:48 PM   #2 (permalink)
MountainMan's Avatar
MountainMan wants to know Dino or Syn?
Damn! That sounds like a problem I would like to have!
MM
2008 FLHX - Baisley 103 cid - 10.2:1 - 97 hp - 107 lbs. torque
MountainMan is offline   Reply With Quote Quick reply to this message
Old 04-04-2011, 03:05 PM   #3 (permalink)
Lost Hippie's Avatar
Lost Hippie wants to know Dino or Syn?
Sounds like a class-action lawsuit in the making...
Lost Hippie...
Following the adventures of Hogg Ryder and Ol' Poop....
97 FXSTC
No compression
3/4 race cam (one lobe worn off)
4 neutral tranny (1-N-2-N-3-N-4-N-5)
Size 10.5 brakes
Arc, spark & zap wiring (fuses by Mini-Mag™)
Air inspection slots in tires
No oil leaks
Lost Hippie is offline   Reply With Quote Quick reply to this message
Old 04-04-2011, 03:08 PM   #4 (permalink)
CuMoFo's Avatar
CuMoFo wants to know Dino or Syn?
Do you have a photo so we may better diagnose the root cause?
Support the Saints M/C!
CuMoFo is offline   Reply With Quote Quick reply to this message
Old 04-04-2011, 03:38 PM   #5 (permalink)
HogDreamer's Avatar
HogDreamer wants to know Dino or Syn?
Is the 120 as hot or hotter than the 110 as far as operating temperatures? The 110's I've ridden could probably keep my house warm in the middle of winter.
HogDreamer is offline   Reply With Quote Quick reply to this message
Old 04-04-2011, 03:48 PM   #6 (permalink)
C-Cat wants to know Dino or Syn?
Those are the best kind of issues to have!
124 ci. 07 Streetbob
107ci. 2011 RGC
C-Cat is offline   Reply With Quote Quick reply to this message
Old 04-04-2011, 04:48 PM   #7 (permalink)
Ironbutt
MilesToGo's Avatar
I can somewhat relate with my recent 107 build. I haven't been burning any tires or popping any wheelies. I'm sure it'll do both but at my age i tend to be a little more conservative. My problem is the bike does not want to go slow. It's real easy to run through the gears and be doing 70 mph before you even think about hitting 5th gear. Everyone around me seems to be going in slow motion.
Current bikes in the stable:
2009 Street Glide
2003 Heritage Softail Classic
Old 04-04-2011, 05:51 PM   #8 (permalink)
redfxr wants to know Dino or Syn?
post a vid of you doing some roll on wheelies at will.
Im a little sceptical.
redfxr is offline   Reply With Quote Quick reply to this message
Old 04-06-2011, 06:26 AM   #9 (permalink)
155" R&R TwinCam
dog155's Avatar
dog155 wants to know Dino or Syn?
Those 120+ cubic inch motors have that affect on us throttle jockeys.Keep the rubber side down.
dog155 is offline   Reply With Quote Quick reply to this message
Old 04-06-2011, 06:33 AM   #10 (permalink)
Sniper
gunnysgt's Avatar
gunnysgt wants to know Dino or Syn?
I'm curious, does the 120R motor allow you to keep your cruise control?? Some of the earlier builds did not. How about it??
gunnysgt is offline   Reply With Quote Quick reply to this message
Old 04-06-2011, 07:52 AM   #11 (permalink)
guydoc77's Avatar
guydoc77 wants to know Dino or Syn?
I propose a final solution. You'll just have to put a 120R into the "other bike" as well. Then, if cause and effect are truly at play here, you will ride both bikes in the same proportions as before.
2008 Road Glide
Phoenix Customs Bagger Brace
Glide Pro
Clearview windshield
107
CP flat tops
R&R Stage 3 heads, .030 gasket, 82cc chambers
Trued, welded, and balanced crank by Hyperformance
TMan 590 cams
SE AC
HPI 54mm TB
Supermeg with open cap and 15 discs
TTS tune by BVBob
2003 Indian Scout Deluxe
Aspen White (got it for my wife)
S&S "SuperStock" 88"
12" apes
Scary fast!
guydoc77 is offline   Reply With Quote Quick reply to this message
Old 04-06-2011, 09:07 AM   #12 (permalink)
Nik00117 wants to know Dino or Syn?
This is the only logical solution
Nik00117 is offline   Reply With Quote Quick reply to this message
Old 04-06-2011, 09:07 AM   #13 (permalink)
strokerjlk's Avatar
when using a cable throttle T/B....the SE 58mm will have to be modified to use cruise,as it isnt set up for cruise.
I used a HPI cable T/B because I wanted a no hassle cruise setup. all HPI cable T/B'S are set up for cruise. and I just thought the HPI was a better choice.
when using TBW T/B the SE 58 will work,as the cruise is handled via the ECU.
07 ULTRA
AMRA
SE 218
DR 218
Old 04-06-2011, 09:29 AM   #14 (permalink)
DavidT wants to know Dino or Syn?
2011 Victory Vision, Ness twin sucker, Ness Big Honkers, Lloydz VM1 cams, PC5 w/Autotune
2006 Victory Kingpin, 87k miles (sold)
Lloydz 110", 132hp/141tq Freshly rebuilt by me.
DavidT is offline   Reply With Quote Quick reply to this message
Old 04-06-2011, 03:01 PM   #15 (permalink)
Sniper
gunnysgt's Avatar
Thanks Stroker, I suspected my TBW was ECU oriented for the Cruise but wasn't sure. I know the older cable type needed special attention. I sold my 2010 Wide glide a couple weeks ago and was seriously considering the 120R for the FLHX. I do take long trips and do need the cruise control.
