Oil Bud Experience : V-Twin Forum: Harley Davidson Forums
Old 07-14-2009, 01:15 PM   #1 (permalink)
davidtn's Avatar
davidtn wants to know Dino or Syn?
Oil Bud Experience
Has anyone had any personal experience with the Oil Bud oil cooler? I've seen their ad in American Iron and am thinking of buying one.
Thanks.
With sufficient thrust pigs fly just fine.
davidtn is offline   Reply With Quote Quick reply to this message
Old 07-14-2009, 02:04 PM   #2 (permalink)
choochmalooch's Avatar
choochmalooch wants to know Dino or Syn?
Cool July Baggers Mag
There is also a step by step install with photos in the July edition of Baggers Magazine. The August edition has the digital temp gauge install to go with it.
"Everywhere is within walking distance if you have the time."
2012 FLHTP
2003 FLSTF
1. Ride
2. Wash
3. Rinse
4. Repeat
choochmalooch is offline   Reply With Quote Quick reply to this message
Old 07-14-2009, 02:06 PM   #3 (permalink)
Ibc
Ibc's Avatar
Ibc wants to know Dino or Syn?
I haven't looked into Oli Bud. I put a Jagg oil cooler on mine.
03 Ultra Classic Electra Glide, stock, and keeping it that way................I hope
Ibc is offline   Reply With Quote Quick reply to this message
Old 07-14-2009, 04:41 PM   #4 (permalink)
davidtn's Avatar
I assume you're happy with it? How much has it lowered your temps?
Old 07-15-2009, 11:43 AM   #5 (permalink)
DeluxeAl wants to know Dino or Syn?
I got a Jagg Oil cooler on my bike, 2005 Deluxe, low mounted. It lowered the temps about 20 degrees measured from the oil dipstick thermometer. The low install makes it look like it came on the bike.
DeluxeAl is offline   Reply With Quote Quick reply to this message
Old 07-15-2009, 12:11 PM   #6 (permalink)
Ibc
Ibc's Avatar
Davidtn, I don't know exactly how much my temps lowered. I can tell you that I ran my bike at idle for 45 minutes while I was tweeking the map on my Thundermax, and the engine temperature never went avove 238 degrees.
I mounted a 10 row cooler just above my regulator. Jagg doesn't have this configuration for an Ultra. So I made my own bracket, had to cut a notch in my lower fairing to allow the lines to connect the adapter and cooler together. I mounted the cooler on the bowtie between the down tubes.
I Googled oil bud oil coolers and found some good posts on the cvoharley forum. Most were negative due to the cooler being mounted so close to the road.
Old 07-15-2009, 12:26 PM   #7 (permalink)
cincyMAT wants to know Dino or Syn?
Could you post some photos of your Jagg mount? I just installed a 10 row Jagg on my 09 RG. Don't think it's getting any airflow using the below the regulator mount.
Sorry to hi-jack this thread. I looked at the Oil-Bud cooler and would have bought one if I hadn't already bought the Jagg. Looks like it has more cooling area than any of the others I've seen.
Thanks,
Mark
cincyMAT is offline   Reply With Quote Quick reply to this message
Old 07-15-2009, 06:52 PM   #8 (permalink)
davidtn's Avatar
I watched video of the Oil Bud and they went in depth about how tough it is...they beat it with a sledge hammer and even shot it with a shotgun. It still held 150 psi of pressure. Seems like it's tough enough to me.
I'm leaning toward it based on my research so far. Another thing I like about it is it is virtually undetectable to the casual observer. That's the one thing I don't like about some of the other oil coolers I've seen is that they are usually easily noticed.
Old 01-16-2010, 02:29 PM   #9 (permalink)
kg4p wants to know Dino or Syn?
Oil Bud
I just installed an Oil Bud Cooler on my lowered '09 FXDC after several months of digging for the best product on the market. This is the creme de la creme of coolers available... I ride a lot of gravel roads and this is a virtually indestructible product. Install was easy. Results are more than satisfactory; excellent form, function, and design. I don't care what you run over, you won't have to worry about this unit leaking, clogging, or losing effectiveness. It is strong enough to jack the bike up on. If you don't know what you're looking at you won't know it's there. One bolt moves it out of the way to access your oil drain plug... positioning of O2 sensor on some aftermarket exhausts may require you to slightly move the engine back in the rubber mounts for the oil filter to clear the frame but it is a simple workaround... well worth any minor imposition. Bud Clarke deserves recognition for his thought, time, and dedication to Harley riders.
kg4p is offline   Reply With Quote Quick reply to this message
Old 01-16-2010, 03:29 PM   #10 (permalink)
something that strong would lack ability to transfer heat and would be heavy, no?
Old 01-29-2010, 07:47 PM   #11 (permalink)
Talking Oil Bud
the oil bud is strong and aluminum, very lightweight, superb design... manufacturer's test results... bike idled until oil temp reached 250... oil exiting the cooler was 156 with no air flow...
Old 01-30-2010, 07:21 AM   #12 (permalink)
Captain Oblivious
Fred1369's Avatar
Fred1369 is still riding a stock bike Fred1369 is still riding a stock bike
you really paid $595 for a cooler?
Fred1369 is offline   Reply With Quote Quick reply to this message
Old 01-30-2010, 08:10 AM   #13 (permalink)
Moneygreen
arealinvestor's Avatar
Sounds & looks like a great product;Anyone running one on a big ci build??
T-Man gear crank set
Jagg 10 row oil cooler
K&P engineering oil filter
To much more to list!!!!!!
Old 01-30-2010, 09:51 AM   #14 (permalink)
Doof! There it is.....
'05Train's Avatar
'05Train wants to know Dino or Syn?
Jagg 10-row mounted on the downtube for me. Big difference in oil temperature (I haven't seen over 205* yet). I imagine it'll go a bit higher in the summer, but I don't have to worry about the motor cooking itself.
The oil bud is an interesting idea, but I'd rather not have it underneath the bike and have to move it every time I mess with something down there.
'05 Vivid Black Night Train
Lots o' black
103 by Dave at JD's
116.70/116.01 SAE
'10 Scarlet Red/Vivid Black Electra Glide Ultra Limited
Stage 1, Intiminators, 575s
'05Train is offline   Reply With Quote Quick reply to this message
Old 01-30-2010, 10:11 AM   #15 (permalink)
rob71458's Avatar
rob71458 wants to know Dino or Syn?
I would be afraid that something like a parking lot speed bump would rip it off. As much as I try to avoid it, I have scraped the lower frame rails crossing over those damn things.
rob71458 is offline   Reply With Quote Quick reply to this message
