Pro PadUpbeat AudioBikeBanditSoCalCoversLawTigersWheeldock.comArnottAirRideProCharger.comEagleRiderD2Moto
Go Back   V-Twin Forum : Harley Davidson Motorcycle Forums > Technical Discussion Forums > Electrical Forum
HillsideCycle
Old 07-23-2008, 06:24 AM   #1 (permalink)
Av8r3400's Avatar
Av8r3400 is on a distinguished road
2002 FLHR Cruise Control
The wife's 2002 FLHR Cruise Control has quit working.
The power switch lights when turned on, but it will not take a "set". I installed the unit myself, so I am familiar with the mechanical and electrical hookups. The control unit is getting power (light on power switch) and all plugs are tight and not corroded. The cable to the throttle body is good. I took apart the "set" switch in the throttle grip and it *looks* fine with no mechanical breakage or corrosion evident.
Do these control units go bad?? Is there something else I should check on before I spring for an entire new control?
Thanks, guys.
Av8r2230
Mine: 2000 FLT Hers: 2002 FLHRI
Av8r3400 is offline   Reply With Quote
Old 07-23-2008, 08:45 AM   #2 (permalink)
You! Outta the gene pool!
ChopperDude is on a distinguished road
Get the Service Manual, and do the full process. You can put the system into "debug" mode, and test each of the 'pieces'. Set - Resume - Throttle roll off - brake - etc.
Mine was bad, the resume portion was "always on", not letting the SET switch operate. About to solder a new switch in. I would NOT jump to replacing the main module until testing the system out further. I'd look for pinched wires as well.
ChopperDude
ChopperDude is offline   Reply With Quote
Old 07-23-2008, 08:47 AM   #3 (permalink)
Italics Envy
MegaGlide's Avatar
MegaGlide is on a distinguished road
Make sure your brake light isn't stuck on.
It happens...
Dave
Forty-Three
I'm holdin' out for a 108th Anniversary model...
2005 Ultra
Cool Blue Dragon Sticker on Windshield
Chrome B&S Acorn Valve Caps
Custom Wart on Front Fender
Chrome Oil Filter
MegaGlide is offline   Reply With Quote
Old 07-23-2008, 10:17 AM   #4 (permalink)
sblair is on a distinguished road
And also the throttle cables tension. Too tight and it prevents the Cruise from engaging.
sblair is offline   Reply With Quote
Old 07-23-2008, 12:14 PM   #5 (permalink)
Av8r3400's Avatar
I don't have a SM for the '02, but I do have one for my '00. Would it be the same??
Av8r2230
Old 07-23-2008, 12:20 PM   #6 (permalink)
Av8r3400's Avatar
OOOOOOO!! We just had a 10K done on this bike and the cruise hasn't worked since. I wonder if they didn't tighten up the cables too much!!
Gotta go home and check!
Thanks!
Av8r2230
Old 07-24-2008, 06:00 AM   #7 (permalink)
Av8r3400's Avatar
Gonna bump this back up.
The cable tension was fine, BUT the pressure switch on the idle cable is bad. I unplugged the switch and the cruise works again. It just does not disengage when you push down the throttle.
Can anyone explain how this little switch works? Can it be fixed or is it required to replace the entire cable (as the book says)?
Av8r2230
Old 07-24-2008, 08:18 AM   #8 (permalink)
I'll confess... was a tech for 4 years, and never learned how that particular "switch" worked. Maybe someone else can tell us. But the one time we had one fail, we replaced the cable. Doesn't mean there's not a "fix" though. Just make sure that the rear half of the cable housing is up "inside" the front half, that black bell looking thing. During their adjustment, they might've messed that up.
And I want to clarify what I said earlier about the Service Manual... the cruise diagnostics is not in that one, it's in the separate Electrical Diagnostics Manual, if that's the right title.
Sounds like you have it narrowed down though. If fiddling with that part of the idle cable doesn't let the switch start working, I think you gotta replace the cable. OR... just run it and remember to touch the brake to cut off the cruise.
ChopperDude
Old 07-24-2008, 09:36 AM   #9 (permalink)
Av8r3400's Avatar
My 2000 FLT shop manual did have a diagnostic procedure that I used to find the problem.
That was an awesome tip. After 8 years that book finally paid for itself.
Av8r2230
Old 07-24-2008, 12:49 PM   #10 (permalink)
Maybe in 2000, it was all in one manual. I know that somewhere in there (2002?), they started splitting the electrical diagnostics into a separate book.
Regardless... glad that you figured it out. Changing that cable isn't *too* hard, so you can get that cruise working again.
Mine's been tore down for two weeks, had to get the part in, and haven't swung the time to solder the new switch in. I commute almost 50 miles one-way (mostly highway), and I GOTTA have my cruise!! Best accessory I've added.
ChopperDude
Old 07-24-2008, 12:58 PM   #11 (permalink)
gtnot is on a distinguished road
Personally, I just run without that switch. Let's see...clutch, front brake, rear brake, cruise power switch...yeah, that's enough.
gtnot is offline   Reply With Quote
Old 07-25-2008, 06:35 AM   #12 (permalink)
Av8r3400's Avatar
I couldn't agree more.
I asked the wife, "How can you disengage the cruise on your bike?"
She said, "Tap the brakes or shut it [the cruise] off."
So this is a safety feature she didn't even know existed. I will change out the cable, but not now. Maybe this winter.
Av8r2230
Old 07-25-2008, 06:56 AM   #13 (permalink)
Italics Envy
MegaGlide's Avatar
I never liked disengaging it that way, myself.
Just "feels" like it's hard on it.
Dave
Forty-Three
2005 Ultra
Chrome Oil Filter
Old 07-25-2008, 10:08 AM   #14 (permalink)
I agree.. I always just tap my front brake to disengage. Rolling the throttle back always feels like I'm "forcing" something.
ChopperDude
Old 07-25-2008, 10:17 AM   #15 (permalink)
PR3VS56's Avatar
PR3VS56 is on a distinguished road
Well, yes you are, but it's intentional. Seems wrong, but it's right. You're pulling the idle cable hard enough to click the inline switch. If you didn't need to click hard, the switch would inadvertently disengage the cruise.
'05 FLTRI
K&N, SERT, 95" Dave Mackie Mega-Sphere, Feuling oil pump & LMR-002 (Baisley) spring, S&S Crank, S&S Roller Rockers,
black SuperTrapp SuperMeg 2:1 (19 disc closed cap), RIVERA PRIMO Pro-Clutch, SE 6-Speed, Ride-Str8, heated grips
Pri: Amsoil Syn ATF. Trans: Redline Heavy ShockProof. Crank: Redline 20W60HD
105tq/107hp
Proverbs 3:5-6
Fruit of the Spirit
PR3VS56 is online now   Reply With Quote
