Dan Vance Racing
Old 03-10-2003, 11:48 AM   #1 (permalink)
jbirdt2001
stop light trigger
has anyone else (besides me) tried the stop light trigger?
I have one but not sure if it makes a difference. What is your take on this unit?
jbirdt2001 is offline   Reply With Quote
Old 03-10-2003, 02:15 PM   #2 (permalink)
Diver
Sounds like a prime candidate for the new User Review Module.
A friend will help you move. A good friend will help you move a body.
Diver is offline   Reply With Quote
Old 03-10-2003, 08:14 PM   #3 (permalink)
5150 is on a distinguished road
Waste of money from what I have seen. It's the weight that triggers the lights, unless you have something the city emergency crews have, I don't think they are worth the cost.
5150 is offline   Reply With Quote
Old 03-10-2003, 08:14 PM   #4 (permalink)
flstflee
tried green light trigger,,dont work
flstflee is offline   Reply With Quote
Old 03-10-2003, 08:35 PM   #5 (permalink)
2DEUCE
There are all sorts of technologies for detecting cars -- everything from lasers to rubber hoses filled with air! By far the most common technique is the inductive loop. An inductive loop is simply a coil of wire embedded in the road's surface. To install the loop, they lay the asphalt and then come back and cut a groove in the asphalt with a saw. The wire is placed in the groove and sealed with a rubbery compound. You can often see these big rectangular loops cut in the pavement because the compound is obvious.
Inductive loops work by detecting a change of inductance. To understand the process, let's first look at what inductance is.
If you were to take the inductor out of this circuit, then what you have is a normal flashlight. You close the switch and the bulb lights up. With the inductor in the circuit as shown, the behavior is completely different. The light bulb is a resistor (the resistance creates heat to make the filament in the bulb glow). The wire in the coil has much lower resistance (it's just wire), so what you would expect when you turn on the switch is for the bulb to glow very dimly. Most of the current should follow the low-resistance path through the loop. What happens instead is that when you close the switch, the bulb burns brightly and then gets dimmer. When you open the switch, the bulb burns very brightly and then quickly goes out.
The reason for this strange behavior is the inductor. When current first starts flowing in the coil, the coil wants to build up a magnetic field. While the field is building, the coil inhibits the flow of current. Once the field is built, then current can flow normally through the wire. When the switch gets opened, the magnetic field around the coil keeps current flowing in the coil until the field collapses. This current keeps the bulb lit for a period of time even though the switch is open.
The capacity of an inductor is controlled by two factors:
The number of coils
The material that the coils are wrapped around (the core)
Putting iron in the core of an inductor gives it much more inductance than air or any other non-magnetic core would. There are devices that can measure the inductance of a coil, and the standard unit of measure is the henry.
So... Let's say you take a coil of wire perhaps 5 feet in diameter, containing five or six loops of wire. You cut some grooves in a road and place the coil in the grooves. You attach an inductance meter to the coil and see what the inductance of the coil is. Now you park a car over the coil and check the inductance again. The inductance will be much larger because of the large steel object positioned in the loop's magnetic field. The car parked over the coil is acting like the core of the inductor, and its presence changes the inductance of the coil.
A traffic light sensor uses the loop in that same way. It constantly tests the inductance of the loop in the road, and when the inductance rises, it knows there is a car waiting!
So a little O'l magnet ain't gonna do much
Don't ask to ride my bike and I won't ask to ride your O'l Lady.
2DEUCE is offline   Reply With Quote
Old 03-10-2003, 09:28 PM   #6 (permalink)
Pestilence
Flyer is on a distinguished road
Harleys are classified as "heavy"........no problem triggering the pad. Used to do it on the Interceptor (500+me,) and the Sporty (400+me)
Never failed.
Rrrrrrroll up to the pad and (modulate) hard on the front brake!
Flyer is offline   Reply With Quote
Old 03-10-2003, 09:43 PM   #7 (permalink)
jbirdt2001
the city I live in uses the magnetic field that 2deuce describes above. I am not sure if my trigger works or if I am just luck at stop lights.
