Excessive Oil Consumption? - Page 2 : V-Twin Forum: Harley Davidson Forums
Old 06-15-2007, 09:00 AM   #16 (permalink)
Highly Seasoned Rider!
newultraclassic's Avatar
Personally, I don't think that 4,000 miles per quart is excessive oil consumption, If you can get them to install the updated oil seals that would be fine.
Air cooled engines will normally consume some oil.
Old 06-15-2007, 09:05 AM   #17 (permalink)
springer-'s Avatar
Originally Posted by dusty67
They topped it off and I am to monitor the use for the next 500 miles. It then goes in for the 5000 mile service and monitor some more. They didn't mention the "issue" with the 05 valve seals but aren't trying to get out of anything either. I did purchase the extended warranty.
If it were me (and I am not recommending you do this), it would be a 1-1.5 quarts low when I brought it back after 500 miles. This would insure they correct the leaking valve seals.
Check out Ride of the Month
207-621-8089
Old 06-15-2007, 09:07 AM   #18 (permalink)
springer-'s Avatar
My shovelheads don't use that much oil in 4000 miles. They don't even leak that much in 4000 miles
IMO, it does not mater how much oil the engine consumes, the valve seals should not leak. If they leak, it is a problem and it has a fix.
207-621-8089
Old 11-12-2012, 07:09 PM   #19 (permalink)
jon_doe is on a distinguished road
SPRINGER i like that one ..
jon_doe is offline   Reply With Quote
Old 11-12-2012, 07:43 PM   #20 (permalink)
tmd11111 is on a distinguished road
My old 05 burned a qt every 1000 miles from new. Dealer replaced the valve guide seals because it was an early model with the old style seals. Well a couple of thousand miles and a couple of quarts later they had to replace the rings on the front cylinder and hone the cylinder. The rings had the end gaps lines up. After that the oil level was always still full when I changed it every 5 thousand miles.
tmd11111 is offline   Reply With Quote
Old 11-13-2012, 07:05 AM   #21 (permalink)
RG50 is on a distinguished road
How do you guys find these 5 year old threads?
2011 Electra Glide Limited
RG50 is offline   Reply With Quote
Old 11-13-2012, 04:24 PM   #22 (permalink)
R1Geezrglide's Avatar
R1Geezrglide is on a distinguished road
Doood, I was totally sucked in to this one...Doh! I have an 05 that had not been updated and used 1qt per thousand. I replaced the heads with CNC'd ones from AMS. The MOCO stopped reimbursing dealers for this several years ago....
R1Geezrglide is offline   Reply With Quote
