» Buyers Guides |
10-21-2005, 11:15 PM
#76 (permalink)
Originally Posted by springer-
Read post #28 again as it is the only other thing I can suggest. It takes bringing the bike into the dealer to have a stock flash reinstalled to correct the problem it talks about. It may be what you need to do also.
I am out of suggestions otherwise.
re #28, reading this the first time is what made me think i had the same problem, but i got no responce from my pc at all.
anyway i took the scoot into the local HD dealer and i did indeed have it hooked up to the wrong connector under the seat. ( i had called the same dealer the day before and was told this was the computor link) . the one to use ( 03 flhrsei2) is on the starboard side under the side cover. he hooked his putor up first so i don't know for sure if i could have link up w/no problems or not. never no now. he did come up with a new dwnload that was more current than the one i had in the bike but it was an "invoice " load. meaning i would have had to pay for it. after knowing which plug to use i hooked up to that one ( i had my laptop with me) and the dwn load took. he could not tell me if the new "invoice" map would take out what i just installed so we did not go that route.
anyway i dwnloaded the best map for my scoot and it ran like a top.
BUT (always one of those, right) i made a run of mabe 30 -40 miles and when i pulled over the dip stick heat guage read 238 degrees. now i live where i had on today full leathers and thick gloves.
question for the board???? this is to damn hot RIGHT( translated still to damnd LEAN )?? any CVO owners want to chime in and tell me what temp your at in full leather conditions...
stock 03-CVO other than A/C and slip on bassanis's ( 4"). anybody got a map?
PS -- RE: " I am out of suggestions otherwise"
thanks for taking the time to make them......
10-24-2005, 05:01 PM
#77 (permalink)
Great post super info. SERT looks like agreat why to go. Can you tell me what the max rpm it will let you go and will it work with a power commander i no i realy would not need it the only problen is all the shops i call do not know how to tune the SERT and we have a shop that does a great job with the power commander. or is thier another way to raise the rev limit .
THanks!
"Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways, Totally usedup, totally worn out and screaming,
'HELL YEA-what a ride!!!!!""
10-24-2005, 06:14 PM
#78 (permalink)
Doofhead
THanks!
where are you located in Illinois?
There are some folks that know the SERT and are excellent tuners.
SERT Rev limiter goes to 7500rpm
I have a TC B motor, so I limit mine to 6000. 6200 is max on a B.
'05 FLSTCI - Cobalt Blue w/ Candy Flames [custom paint by VonRaknid]
Chubby WO515 Bars - 18" Fat Daddy 50's w/ ME880's - GMA Brakes - Baker DD6 - 95" w/ SE Cast Flat Tops - Street Ported Heads 9.9:1 CR - [Engines by Otto] - Andrews 37G - 1.675:1 Rockers - Dakota Kid Delphi TB/Intake - SERT tuned by Otto - RB Racing LSR 2:1 - 96hp/106tq
10-26-2005, 10:05 PM
#79 (permalink)
Ridin' with the King
This needs to be a sticky in the EFI Maps forum.
10-29-2005, 01:28 AM
#80 (permalink)
The EFI forum doesn't allow pictures it seems, so it will have to stay here.
207-242-8374 Cell Phone
207-621-8089 Port Shop/Dyno Shop
11-04-2005, 06:43 AM
#81 (permalink)
wow!!! you da man, Springer!!!!!!!!!!
thanks for the easy to understand definition of the SERT.
11-19-2005, 11:57 AM
#82 (permalink)
Springer, I thank you for all the time and effort you exerted to help others
learn more about the SERT. You have opened my eyes to a number of different
options I may attempt on my own and forego the added dealer fees. When I purchased my SERT I did so for the convenience of tinkering,so far only the Dyno Tech has used my unit and everytime I have had a charge ( $$$) for him to do so.Also my SERT package has been kept at the dealers to be sure nothing will be lost. I believe I will see if my Tech saved the last Dyno Tune info and ask if I can have a copy.
12-02-2005, 09:16 PM
#83 (permalink)
Originally Posted by The_Snowman
Springer, what happens if you crash your laptop with the SERT software on it? Can you re-stall on another computer? Can anyone's software connect and read other bikes as well or is it a bit like Microsoft? How does the dealer read all bikes, guess they have a universal type program? Thanks, John
First, really good stuff, Springer!
Springer's answer a few posts back pretty well covers this. However, as a long-time computer consultant, I always advise clients to back up vital files. I expect a map which you worked on for long time would be considered a vital file.
You could do this by burning the files to a CD, but this sometimes changes the "attributes" of a file. Not difficult to change back if you're experienced with computers but if you're not conversant with them, a somewhat better way of saving files may be to use a Zip drive. Also, if you are hooked up to a home network, you could also save them from your laptop to a desktop.
12-06-2005, 06:03 PM
#84 (permalink)
Very interesting topic. Does anyone know who exactly is manufacturing the sert for HD? Do they have a Website with more info on the product?
12-06-2005, 06:49 PM
#85 (permalink)
Don't know who manufactures the interface, but the SERT Software is
Copyright The Turbo Shop, Inc. 2001-2005
12-08-2005, 06:40 PM
#86 (permalink)
SERT Manual
Where is the PDF you spoke of?
12-14-2005, 04:54 AM
#87 (permalink)
Doing time, behind bars!
Ignoring you are they?
FXSTDISWILD,
Welcome to the forum. The PDF files (2) are within this thread, you may have to read it right thru again & watch for it. I can't tell you which page it is on because there are different settings for the number of posts displayed per page - I have mine set at maximum and the PDF fileis on Page 2, yours may be different.
Hope that helps, John
12-14-2005, 08:35 AM
#88 (permalink)
Post #8 ........
12-21-2005, 08:22 AM
#89 (permalink)
Race Fueler
Springer:
Do you or does anyone have any thoughts on the HD Race Fueler or just experience with the Race Tuner?
It is significantly cheaper, I know it doesnt have all the tuning ability as the Tuner, but I am interested in what exactly it does do if you arent planning on installing more than Stage 1 and pipes.
Very nice post by the way. Informative and insightful.
01-08-2006, 08:45 PM
#90 (permalink)
SERT MAP Files
Springer,
As a new member to this forum, thanks for the post with all of the great information. This was top notch and is exactly the kind of information and education that I, as I'm sure others came to this forum for. Thanks for the excellent post.
A questions that I don't believe have been asked/answered:
As we now know we can't restore our original Map back to the ECM with the SERT, can we get the original factory Map from Harley, or are the only maps available on the SERT CD. Seems as if the dealer can get them for the TECHPC Map Restores, so it would seem appropriate that we should be able to get the map as well (of course for $$$)?
2. Are the 2006 maps for the new Dynas with the closed loop O2 sensers included in the current version of the SERT? How often are the maps on the SERT added too? Do you have to buy a new SERT to get them? I know, this is really 3 questions. Sorry.
Thanks Again,
Ron
2006 35th Anniversary SuperGlide #749
