Pro PadBikeBanditRacer SupplyUpbeat AudioSoCalCoversLawTigersEagleRiderPowersportModels.comMotorcycle.comD2Moto
Old 05-18-2008, 07:18 AM   #16 (permalink)
Doofhead
Originally Posted by firehog383 View Post
I already have a set of S/E heads that have been cleaned up a little, and a set of woods TW-5 chain driven cams that are bolt in for theese heads roller rockers and S/E support plates, stroker flat top pistons that are 10.5 static for the heads. I got a deal on the heads and had a local head porter clean them up. Will this work or am I better off starting over.
In post #7 you mention the TW6, which cam is it? the 5 or the 6?
I think you would benefit reading this past thread on how cams work and what all the numbers mean.
http://www.v-twinforum.com/forums/v-...bers-mean.html
If you are saying you already have the SE Pro heads at 76cc chamber size and the TW5 cam, that combination with the flat tops would give you high cylinder pressure due to the early intake close. This combination will be very prone to pinging.
If you want to stay with the SE heads, you would be better off with a much later closing intake to help bleed off some of the compression. You might be able to get the TW8 to work but someone will have to check valve clearances.
Something I mentioned earlier is using your stock heads and having those modified to work with either the TW5 or 6, whichever one you have.
'05 FLSTCI - Cobalt Blue w/ Candy Flames [custom paint by VonRaknid]
Chubby WO515 Bars - 18" Fat Daddy 50's w/ ME880's - GMA Brakes - Baker DD6 - 95" w/ SE Cast Flat Tops - Street Ported Heads 9.9:1 CR - [Engines by Otto] - Andrews 37G - 1.675:1 Rockers - Dakota Kid Delphi TB/Intake - SERT tuned by Otto - RB Racing LSR 2:1 - 96hp/106tq
Totenkopf is offline   Reply With Quote
Old 05-18-2008, 09:17 AM   #17 (permalink)
BEADMAN
adlerx's Avatar
adlerx is on a distinguished road
Sell those SE heads and use the $$ to have your heads ported and set up for the right cc's that you need to achieve the compression ratio desired. Use flat tops with the tw6 and have your head guy set your heads for 10.1 CR and you'll be a very happy camper. Don't forget the 1.9 intake.
You don't seem to be grasping how the combustion chamber volume affects the compression ratio. Try this calculator, it may help you grasp it better http://www.bigboyzcycles.com/TwinCamComp.htm
2008 Road Glide, little of this, little of that, really quick and fast
"Ahhh women! Aren't they just the best? I love em all and they all love me!" Denny Crane, 2007
adlerx is offline   Reply With Quote
