» Buyers Guides |
05-15-2008, 12:10 AM
#61 (permalink)
Originally Posted by cts1950
Larry
What was the run out on the crank and the back lash on each of the drive gears? What I am thinking that the georotors can't rotate in the center of the bores for some reason. Chain drive is more forgiving to crank run out. The minor differences in manufacturing could change the gear drive set up from one cam plate to another. I know these are more straws but we are starting to run out.
Its well within the spec`s, its better than most i`ve seen
yeah i agree, i`m all out of ideas... most likely going to put the stocker back in it real soon
thanks buddie
(larry)
05-15-2008, 12:39 AM
#62 (permalink)
Larry
Keep us informed on the outcome of putting the original parts back in.
The one thing that keeps going through my mind. is the oil pan gasket the oil passage goes through the gasket surface. If the gasket were damaged at the oil port it could suck air. one way to test this theory out would be to overfill the oil tank so that the level is well above the joint between upper and lower halves.
Good luck
Chris
05-15-2008, 02:34 AM
#63 (permalink)
Big Huge thankyou to you ALL...!!!!!
Larry
Good luck
Chris
Hi Chris...
i have already had the oil pan out of the bike few days ago, didnt find anything wrong, the original gasket was fine... i reinstalled the pan & new gasket, new oil & filter. I had also put the original camplate/pump back in a few days ago to see if i had the same issues, and the original pump has great pressure and flow. So i`m kinda ruling out everything before the camchest on back to the oilpan.
I will surely let you guys know what i find out when i find out the problem with this SE Billit pump kit.
A big HUGE word of thanks to you ALL, on this forum,
for ALL your help & idea`s, i am forever greatful to you all.
(larry)
05-17-2008, 12:48 AM
#64 (permalink)
Well the weekend has arrived, time to tear it down and look this camplate & oilpump over one last time
05-17-2008, 10:06 AM
#65 (permalink)
End of Story for the SE Billit Camplate/Oilpump Kit...!
Didnt find anything for the last time.... even after installing the "support kit"
so i`m out over $400 bucks for this SE billet camplate & oilpump kit
Special ordered, not refundable...! Makes a nice conversation piece for my garage wall though.
Put the stock camplate (w/baisley spring) and stock oilpump back in the bike, oil light out, great oil pressure again....
now its time to ride...!
Ya`ll ride safe, and thanks to you all once again for all your help and advice...!
(larry)
05-17-2008, 10:17 AM
#66 (permalink)
GHOSTRIDER LIFE MEMBER
Larry send the camplate and pump to R&R CYCLES ask Reggie to look at it to see if he can figure it out... R&R likes a challenge all it will cost you is the shipping...
131" KING OF CUBES * HYPERFORMANCE * R&R CYCLES R&D BUILD
INNOVATORS NOT IMITATORS
"YOU CAN'T SOLVE PROBLEMS BY USING THE SAME KIND OF THINKING YOU USED WHEN YOU CREATED THEM"
05-17-2008, 11:34 AM
#67 (permalink)
Wow thats awesome...!!!!  and THANKYOU for helping with advice...!
Surely i`d pay them to figure it out, because this thing just has me so dam baffled...!!!! I`d really like to find out what`s going on with this SE billit camplate oilpump kit. I`ve built hundred`s of motors in my 50 years of life, an i`ve never had a job stump me so badly....lol. (i`m embarassed to even think about this one...lol)
Do you happen to have "Reggie`s" contact info...? Do you know him really well...?
If you do know him personally, could ther be a chance you could give him a heads`up on whats goin on for me...?
Thanks again buddie.... i am so greatful of you guyz...!
05-17-2008, 05:44 PM
#68 (permalink)
1-603-645-1488 just ask for Reggie (Sr. or Jr.) tell them Tim from Prescott, AZ told you to call... R&R will do the testing and tell you what's up with the camplate and oil pump...
05-17-2008, 05:45 PM
#69 (permalink)
when the answer is known please be sure to let every one know what the problem is. This has been a mind boggler.
05-18-2008, 12:31 AM
#70 (permalink)
The SE Billit Camplate & Oil Pump Live`s...!
The SE Billit Camplate & Oil Pump kit Live`s...!!!!
Hey guys, i just couldnt let this alone an let it beat me.... this afternoon, (before i was about to make the camplate my new expensive wall hanger...lol) i ripped into this camplate again.... i was just so conviced that, that was where the problem was at... and sure as all mighty, i found a blocked port in the camplate, and thats why it wasnt getting any oil to the pump. (man i looked inside that thing a million times, never saw anything before this time) Good reason why the pump and the chest cavity stayed so dry. It looked like it just wasnt cleaned out very well after the machining process. It was a big machined chip that got stuck in it... lodged all the way accross the port when ever it tried sucking oil. (these camplates are anodized black... you cant see sheit inside of them... only way i saw down inside was, i made a fiber optic light, stuck it down EVERY port hole, thats when i saw something inside of it.) Anyway, i got the debris out of it, pulled the bike back down and put the SE kit back in, and holy shidski, oil pressure instantly...!!! Before i actually ran the engine, i pulled the oil pressure switch on it before i turned it over and hooked a gauge to it... spun the motor over until i saw the gauge build up pressure, then i knew for sure that i found the EVIL problem. The motor might have turned over twice and the pressure popped right up nicely...! Cold engine was 60psi - Warm was 55psi
Hey you guyz, thankyou so very very very much for stickin this out with me... as i`ve said all along, i am forever greatful to you all for your help, thoughts and idea`s. I knew this was baffling you guys too... i just HAD to find out what the hell was going on with this thing, i just KNEW it had to be something retarded. For a few momments at time`s, i thought i was really loosen my mind over this weird episode.
(larry)
05-18-2008, 12:50 AM
#71 (permalink)
F$ck Google ads
Glad that you solved the mystery. Imagine the metal chip would have ground up your engine once it came loose. That would have been an even more complex riddle.
Have fun riding the beats
2003 FXST gunmetal pearl
Revolution 107 "
Dewey's 107 heads @ 10.7
Andrews 67 G
SE CV44, SE a/c
Baker DD6
RB Racing 2-1 'Black Hole'
2008 FLHTCU dark blue pearl
103 "
Woods 6
SE a/c, SERT
S&S SPOs
After Douglas Adams RIP
05-18-2008, 01:23 AM
#72 (permalink)
 AMEN TO THAT Vienna...!!!
05-18-2008, 10:40 AM
#73 (permalink)
Happy you had the satisfaction of finding the problem. I used to work for a hydraulic systems manufacturer. Their claim to fame was building complex manifolds. They had a at least five people who's job was making sure all holes were connected and of coarse ones that should not be connected. They used fiber optic lights pipe cleaners and carbide burs on 14" long 1/8" shafts to get inside to clean up that the drills missed. I think the MOCO needs a letter from you and what you found.
GOOD SLOOTHING AND RIDE SAFE
Chris
05-18-2008, 11:32 AM
#74 (permalink)
Chris
Hi Chris
i got lucky buddy, thats all. Had i not built a little fiber optic light to look down inside, i would have never seen it sitting inside the camplate. The chip was just about right AT the intake side of where the pump sits on the camplate, but you couldnt even see the chip at the pump side either. Kinda fell between the spot where you cant see anything from either end. Lucky find bro, just lucky.
Yes, the MoCo is getting a letter on what happened and what i found. My only hope is, that they`ll look into it and fix the inspection precedure`s with the vendor that makes these camplates so that knowbody else has to go thru this ever again. I`m sure it was just a fluke that it happened, BUT still, the hell i went thru...!!!!! Anyhow, i feel really good about it bro, at least i know i`m still good at buildin motors after all this went down. It surely belittled me i tell ya...lol. I just couldnt convince my self that it was something i was doing wrong... i`ve built hundreds of motors in my life, and i wasnt about to let this one beat me...lol, or be the last one i ever built or give up on.
Chris... thankyou for all you`ve done brother... i owe you
(larry)
05-18-2008, 11:36 AM
#75 (permalink)
Dyna_Willie
WOO HOO! Great job, glad you didn't have to replace the cam plate!
Life is short, enjoy the ride!
1999 FXDWG w/some extras
