Originally Posted by Vapor Trail
I have an '07 Dyna Wide Glide with stage 1 and Python pipes with the Powerchamber in it (same as the V&H BSS). Next week I'm getting a big bore 103 kit installed with polished heads and S&S 585 gear drive cams. The bike will also be Dyno tuned after install. What should I expect in terms of hp and torque gains? The stage 1 dyno tune read 74hp and 83.5 torque. Also, I'd like to keep the same pipes on it (with the stock baffles) but the shop thinks that after the work I might need to change the baffles. Any thoughts? And if so, any suggestions on some other baffles and where to get them?
Thanks much! Your input is appreciated! Scott
If your dyno operator knows how to read a graph, one or two pulls should reveal to him if you need more or less exhaust flow. For a person to say you have to change the baffle in the pipe either has to have lots of experience with that package or very knowledgable on the exhaust system which brings me to this point....I haven't seen too much of this experience in the dealers I have trained, now that's not to say there isn't some good techs running the dyno in the dealers because there are.....but in the same breath there aren't that many.
I'll let the rest of the board remark on your choice of cams and heads, I have my thoughts but I'm too bias on the Woods and Andrews line to give you a fair assesment on the S&S line of cams.
God Luck
