StoneyStraps.comProCharger.comRacerPartsWholesaleBikeBanditLawTigersCheapCycleParts.comDaytona Twin-TecPerformanceOilTechMotorcycle.comSportbikeTrackGearKomodoGear.comEagleRider
BikeBandit
Old 03-08-2008, 08:46 AM   #31 (permalink)
FLHR2000 is on a distinguished road
I am simply saying this.
The implication is: "if I do your heads, this is what you get".
FLHR2000 is offline   Reply With Quote
Old 03-08-2008, 09:04 AM   #32 (permalink)
KingofCubes's Avatar
Originally Posted by FLHR2000 View Post
KOC, just so I am not confused I am going to ask you to clarify the probing thing, you make it sound as if he probes the port and makes adjustments based on the shift or position of the port, correct?
This is correct, if you know where the center of chamber and center of valve are this is possible and instead of cleaning up the whole shifted port to make it look like it has been cnc machined, he chose to clean up one side and hand blend to the other to keep the velocity up (on the unwelded heads) and fill in the recesses on the welded ones. It's amazing to see. If your ever in N.H. stop in and get the nickel tour.
King Of Cubes
515-266-6381
www.kingofcubes.com
Old 03-08-2008, 10:42 AM   #33 (permalink)
Originally Posted by KingofCubes View Post
Many cnc porters do it that way as did Reggie Sr back in the day when he started but he has since switched to a probeing process so he can identify and adjust core shift on the fly because what he found was the core had shifted .030" to the left and the machine was taking out material on the right that the velocity would be down on that head so he uses the dowel locators, the seat, and the port window as reference points and the probe to adjust the machining.
On his billet heads he didn't hand port and digitize because there was no port there to begin with so he designed the whole port in Mastercam. I've watched him make and modify ports a couple of times and now he writes macros and probes them.
Before the probing process, how does the CNC method deal with core shift? or maybe it isn't dealt with?
Thanks for the explanation Randy.
Old 03-08-2008, 10:46 AM   #34 (permalink)
Average Dude
YankeeBob's Avatar
I've had the nickel tour....and then some. About half way through, my head was spinning due to information overload. It was hard to comprehend any more!
Quite impressive what these folks do!
Deut. 23:12-13
Old 03-08-2008, 11:04 AM   #35 (permalink)
I am impressed too. Have had a few good very technical talks with Reggie SR and knowing the CNC control side of things (my day job) I am impressed with his achievements. I have been porting heads since 1973 and never considered makeing any money at it so just did it for my own use with the help of some old timers like Larry Ofria learned oldschool. The CNC has advantages. Grind time is a killer.
Old 03-08-2008, 12:20 PM   #36 (permalink)
KOC, thanks. When I first read your post it sounded like he was abandoning the cylinder dowl datum and isolating the port. I was trying to comprehend how that was eliminating core shift, and not just following it (shift). The sucess he has is solid and I have been puzzled by my misunderstanding.
$.05 tour? That sounds pretty cool.
Thanks again.
FLHR2000
Old 03-09-2008, 10:08 AM   #37 (permalink)
Hillsidecycle.com is on a distinguished road
Power
Originally Posted by nw_guy4_fun View Post
So what are you saying? Distrust the dyno? Others are posted here from the same dealer, same dyno, same operator, same software. This is an honest build and was very well documented on the net with photos of the ports as-cast. Pretty low drama. Same skeptics voiced disbelief before hand. There will be more of the same.
Don,
Little different now that your on the other side of the fence, isn't it?
Get your flack-jacket on now, so you won't take one in the chest, and keep on smilin'.
Scott
Palmer Bros.
Hillside Motorcycle & Machine
V-Twin Performance Center
Munnsville, N.Y.
315-495-6650
www.hillsidecycle.com
"Repairing Broken Torque Curves Since 1982"
Land Speed Record Power
Hillsidecycle.com is offline   Reply With Quote
Old 03-11-2008, 01:53 PM   #38 (permalink)
>Little different now that your on the other side of the fence, isn't it?<
!ROFLMAO!
Old 03-11-2008, 02:19 PM   #39 (permalink)
Yeah me too ROFLMAO
Two tablespoons of metal removed some valve work and over 100/100 from a low compression baby cam 95" motor, no flow bench used. It's human nature that head porters would not like this stuff and call foul, the customers like the offering though. Truthfully I don't think they will all fly this high but will push over 100tq every time with a good pipe and tune and have a very wide torque curve. Perfect for the guy that wants roll-on power and not breaking the bank. Some home shop machinists could do this themselves.
Old 03-11-2008, 02:29 PM   #40 (permalink)
Here is another similar done on the earlier heads just valve changes as-cast ports.
"STREET PORT" Heads, 9.6:1 Compression, Stock TB/Stock Injectors, Andrews TW26G Cams, S.E. Slip-ons
Decent considering not nearly as nice as-cast ports on the earlier heads.
Old 03-11-2008, 03:14 PM   #41 (permalink)
nwguy, I'm not cry'n foul, I just thought it was funny as he!!. You have to admit it was a good one.
Can you post the graph? I can't do the links.
If it's the one on HTT from BD, I saw it. It's a shame there was no bench work, the heads could have been brought up to the the flow rate of the new castings, prior to being shipped and that customer could have gotten his 25 HP.
Still not to bad, I have seen worse.
Old 03-11-2008, 08:15 PM   #42 (permalink)
Power
Attachment 44945
Don,
Looks good.
We just completed an in-house build/install/tune.
80" Evo, Our Stage I Heads, OEM ignition, CV carb jetted, S/E slip-ons, and a Bob Wood 6. Tuned out, on our 150, at 79.9 hp and 91.4 ft lbs in lousey air.
Not bad for an engine 13" smaller, with our entry level head.
Scott
Palmer Bros.
Munnsville, N.Y.
315-495-6650
Old 08-26-2008, 08:26 PM   #43 (permalink)
oryguy is on a distinguished road
Big Boyz Is The Bomb!!!
If you want a quick turn-around, the best time to have Bean work his magic on your heads is in the summer months when he isn't swamped with so many satisfied customers!!!
I had him do my port, polish, CC, and decking. He is very precise to your requests and asks all the important questions (altitude, cams, driving style, loaded weight, etc.).
Bean took all of this into account and made my bike run like a "raped ape" even with the differences found clear across the country in Utah!!!
oryguy is offline   Reply With Quote
