I have decided to go with a bigger build and the Andrews 26h cams will not work anymore with the increased compression ratio.
I installed these cams at the end of July and looking to get $150 for them.
http://www.andrews-products.com/moto...nDriveCams.htm
Camshafts on all 2007 Twin 96" and 2006 Dyna engines use roller chain drives instead of silent chains. All of the cam grinds listed below are designed for use with stock hydraulic lifters. Twin 96" bikes and 2006 Dynas will have the same performance characteristics as earlier bikes with similar cam grinds.
216326 26H
11/35 226 262 .490 .138
41/09 230 266 .490 .112
Stock Bolt-in cams: 88 and 96 inches - stock compression ratio. Great for two-up touring, this cam will add torque and HP at lower and middle RPM ranges. (1800-5200 RPM).
