lean angle sensor : V-Twin Forum: Harley Davidson Forums
Go Back   V-Twin Forum : Harley-Davidson Motorcycle Forums > Technical Discussion Forums > V-Rod Engine
Old 05-16-2003, 08:53 PM   #1 (permalink)
gpp
gpp wants to know Dino or Syn?
lean angle sensor
Does anybody know where the lean angle sensor is on a V-rod and can it be bypassed like it can on other fuel injected harleys. Also, I suspect this is the reason that my v-rod is cutting off when I go around sharp curves or turn from at an intersection. This didn't happen until I left to go to Myrtle Beach this week.
Or if you know that this isn't the problem, let me know what it may be. The bike will restart after about five minutes after it has cut off. Then it will cut off again eventually after a lean.
gpp is offline   Reply With Quote Quick reply to this message
Old 05-17-2003, 06:59 AM   #2 (permalink)
Zeus wants to know Dino or Syn?
the vehicle attitude sensor is located in the tsm/tssm & cannot be bypassed-sounds like a faulty module
I refuse to get in a battle of wit with an unarmed person
Zeus is offline   Reply With Quote Quick reply to this message
Old 05-17-2003, 09:25 AM   #3 (permalink)
VRodDrew wants to know Dino or Syn?
Bank angle sensor
I believe it is part of the TSSM module under the seat.
The bank angle sensor cuts off ignition once the bike passes a 45 degree angle of lean. Since a stock V-Rod can only lean to about 30 degrees without dragging pipes n' pegs (and less than this if you lower the rear shocks) I would suggest that something may be amiss.
It is possible you have a faulty TSSM - if the problem persists, take it to your dealer and have them hook up the Scanalyzer - it will quickly show if the TSSM is malfunctioning.
VRodDrew is offline   Reply With Quote Quick reply to this message
Old 05-17-2003, 10:17 AM   #4 (permalink)
gpp
sounds like no more riding till tuesday since the harley shop closed for bike week.i checked it this morning and it shuts off on any sharp turns.
Old 05-29-2003, 01:58 PM   #5 (permalink)
McKay wants to know Dino or Syn?
Mine was doing this also. It turned out to be a loose connection on one of my injectors that when I went into a lean it making a bad connection......
McKay is offline   Reply With Quote Quick reply to this message
