Leaky Rocker Box
Started blowing a small amount of oil out of the rocker boxes. I do know the parts were 150 bucks, i'll post them once i pick the bike back up, labor was about the same.
The dealer stated that this has been a problem with VR, although it's the first i've heard of it.
To check your bike look very closely beneath the chrome rocker boxes at the top of each cylinder. Be sure to check the concealed area between the cylinder heads and the gas tank. Although I didn't notice the problem until I saw some black power, it's possible there was oil in the concealed spaces that I didn't see.
In particular look carefully if you have the VRB where the black soot will be much harder to see.
Hopefully this is freak thing for me only, but if the dealer is right this is something you should all check carefully.
PS. I have an 02 with about 15k on it.
How's that 'Hope and Change' workin' out for ya'?
