Motorcycle.com Classifieds!Pro PadBub Enterprises
Diamond Bar ChoppersAmerican Side Road CycleRRcycles.comMotorcycle.comJekillandHyde.euProCharger.com
Old 11-12-2004, 01:42 PM   #1 (permalink)
HammerHead's Avatar
HammerHead is on a distinguished road
False Neutrals
Have a 2003 VRSA that I have had no trouble with until lately. On two occassions the transmission will not down shift or up shift but instead moves into a false neutral. The only way to get the gear I'm trying for is to move the shift peddle backward or forward and retry the shift.
Anyone have any ideas were to start.
HammerHead is offline   Reply With Quote
Old 11-13-2004, 09:12 AM   #2 (permalink)
HDV
HDV is on a distinguished road
Check for binding in the shift linkage first. Then maybe try synth oil. Or, it could be something inside. Does it only do it at slow spped or all speeds?
HDV is offline   Reply With Quote
Old 11-13-2004, 07:50 PM   #3 (permalink)
HammerHead's Avatar
No binding at all, and it occurs at all speeds. The only thing that will allows me to up or down shift is to move the shift peddle back and forth. I am running 100% synthetic.
Old 11-14-2004, 10:16 AM   #4 (permalink)
HDV
It sounds internal then. I would have a stealer look at it.
Old 11-14-2004, 01:22 PM   #5 (permalink)
JMS
JMS
Your transmission may be bad, mine went out at 500 miles like that, the engine was replaced. Don't ride it anymore, there is a chance the trans could lock up.
The Nectar is in the Journey.
JMS is offline   Reply With Quote
Old 11-14-2004, 01:41 PM   #6 (permalink)
Haawk - PTUI - Crap
petelogan will become famous soon enough
Sounds like it's inside the box. If it's in warranty, let the dealer have it.
Pete
Hol' My Beer, Bubba, An' Watch 'Is
petelogan is offline   Reply With Quote
Old 11-14-2004, 01:47 PM   #7 (permalink)
Haawk - PTUI - Crap
I have to admit, I didn't understand that. Your tran went out an' the engine was replaced ? I know I've got this wrong
Pete
Old 11-14-2004, 01:49 PM   #8 (permalink)
Haawk - PTUI - Crap
What grade oil you running in the tran ? Syn3 ?
Pete
Old 11-14-2004, 06:36 PM   #9 (permalink)
Z16Monte
Pete
The engine and transmission share a single case.Not seperate like the big twins.No trapdoor like the sportys
Z16Monte is offline   Reply With Quote
Old 11-15-2004, 01:47 AM   #10 (permalink)
Haawk - PTUI - Crap
Thanks. I knew I was right about being wrong, at least
Pete
Old 12-04-2004, 03:44 PM   #11 (permalink)
There was a TSB on that the hd was swapping engines as they did not want the dealship fixing it. I did several that would do that. HD has you inspect the linkage (internal) if there is any movement aone one part that they specify they have you pull the motor and swap it out.
GMR PERFORMANCE
928-445-3473
TTS TUNING CENTER AND SALES
WWW.GMRPERFORMANCE.COM
