It sounds like it just needs bleeding. I have a vacula which sucks it straight through using the bleeder valve in place. You might want to get a used master cylinder cover, puting a steel stem tire valve in, just pop out the site glass, screw it in place, take a small pump like for the suspension, or a bike pump, and ad just a few lbs of pressure, then pump the handle and open the bleed screw.
