CycleGear.comMotorcycle-CommunicationDan Vance RacingJekillandHyde.euPro Pad
Motorcycle.com Classifieds!Fuel MotoBikeBanditDiamond Bar Choppers
Old 01-18-2004, 01:45 AM   #1 (permalink)
pkh
pkh
bleeding the clutch
hello,
I'm new to the Forum. I just replaced the hand controls with chromed ones. I bleeded the brakes but not sure how to bleed the clutch properly. Any help would appreciated.
pkh is offline   Reply With Quote
Old 01-18-2004, 11:14 AM   #2 (permalink)
hippo888
The clutch slave cylinder is on the right side of the bike. Follow the clutch hydraulic line. It's under a small, circular cover secured with 3 screws.
You can do the standard pump, open bleed screw, close bleed screw, release method or use a vacuum pump. Stuff rags between the engine and the exhaust pipes, because this is going to cause a mess.
have fun!
Paul in MI
04 XL883R
hippo888 is offline   Reply With Quote
