Fuel Moto
JardineProducts.comRRcycles.comMBO EnterprisesMotorcycle-CommunicationBub EnterprisesPro PadCycleGear.com
CycleGear.com
Old 11-30-2003, 01:01 PM   #1 (permalink)
Motown_VROD
Gasket Replacements (Cylinder Heads & Alternator)
I've got the V-Rod in the shop to have both cylinder head gaskets and the alternator gasket replaced under warranty. I was dripping oil all over my lower belt guard and rear sprocket.
Has anyone else experienced this failure? The dealer says it was a common problem and HD changed the gasket design to correct the problem.
Joe
Motown_VROD
'03 V-Rod
VMod Exhaust
Screaming Eagle Air Filter
Stage One Flash
28T Pulley
Sundowner Seat
Tons of Chrome Goodies
Motown_VROD is offline   Reply With Quote
Old 12-04-2003, 05:00 AM   #2 (permalink)
HawgDoc
are you sure it was HEAD gaskets? the cam covers have leaked a bit as well as the alternator covers... because of too much chrome making the sealing surfaces not perfectly flat. sanding the covers on surface plates seems to cure the leaks.
if you can't be a good example.... maybe you can be used as a warning to others.
HawgDoc is offline   Reply With Quote
Old 12-11-2003, 04:09 PM   #3 (permalink)
vrodjohn
I had the rear head gasket leaking oil. My dealer said it was the first one he had seen. They had to order the parts and it took about 2 weeks. Have not been able to ride it since I got it back a couple of weeks ago because of the weather. Can only hope that it's fixed.
03 Sterling Silver & Vivid Black V-Rod
05 Vivid Black Road King Custom
vrodjohn is offline   Reply With Quote
Old 12-28-2003, 02:27 AM   #4 (permalink)
HawgDoc
what do YOU do vrodjohn? DO? TEACH? .... or just whine & complain?
Old 01-03-2004, 02:52 AM   #5 (permalink)
Jeff S.
I changed a set of headgaskets on an 01, but I cant really say they were leaking, more of a take care of the customer thing. Did your head gaskets actually leak? I have seen plenty of valve cover breathers and alternator gaskets, but I cant say I have actuallyseen a head gasket leak.
Nostalgia
If its too loud
Your too old
Jeff S. is offline   Reply With Quote
