Wanting to get rid of the brake light
I am in the prossecs of making a new fiberglass fender for my rod. And I would like to remove the rear brake light from the middle of the fender and have the brake light work though the turn signals. H-D just came out with a kit to make you turn singals into brake lights also but as we all know our turn signals are not running lights. This being the problem that I am faced with.
I plan to run the deuce chrome turn signals. this will give me the right socket and bulb for the job, I just need to figure out how to make it all work.
The kit H-D has for the v-rod, it only has the two wires that is needed for the standard setup. They also have one for other bikes. Does anyone know if the connection are the same and will it work.
