That depends on your bike and the person setting up the PCIIIr. The HD flash for your setup works perfectly well for most people. If you're getting the PCIIIr then you don't need additional profram loaded (flashed) onto your ECM by the dealer. You should, however, have the dealer load the updated factory flash for the '02 bikes to correct some idle errors. It's a no cost upgrade but it's not for performance and will not cause any warranty issues.
Mark W.
'03 V-Rod
'00 Buell Blast (Wife's)
