Straight Pipes
Hi Group, new to it, great info. Thought I would share this with you. Saw on a web site how to change out the stock pipes. Drill out baffle/weld at exit of pipes and remove chamber. Then install new baffle. Well I didn't put in baffle & went with the straight pipes (big stock pipes). I currently have the S.E. pipes, H/D download and K&N air filter. 3 bolts and 10 min. later you have the baddest, loudest, different sounding bike that kicks a**. No flat spots. Wear ear plugs for it is loud! I take them off and put the S.E.'s back on for everyday cruising. Throw a twist in it and go topless, it will rev faster but flat spot at 7k. Have fun and bring on the REVOLUTION!
