I know this has been discussed at the forum previously but still, maybe someone who has unplugged the SE 16 gauge double barrels can help me out here. When I peek into the pipes, I see two issues with the unplugging: (1) the baffles seemed to be screwed on and then it is welded - see picture. Is that the same for you guys in the US? What have you done about it, just turn the weld on and de-welded the screw??? (2) is the plug the about two inch diameter plug that is straight in? In any case, I assume that you have to get out the screw to unplug the plug?
Thanks for any insight!
