Radiator Fluid Leaking and a little smoke
My V-Rod has 2800 miles on it and the other day I noticed a redish liquid on the right side of the engine. Didn't know what it was at the time, but I had never seen it.
I've riden a few times since then for short distances and today after a quick trip I noticed more of the liquid. So like a good forum member I searched for coolant and found that some people had the cap or the hose break off the overflow reservoir. So I took the airbox cover and side cover off to see that the coolant was very low (almost nothing in the reservoir) and nothing unusual or broken.
I also couldn't see or feel any coolant where it was leaking from. So I started the bike and let it run for a while and noticed the small hose (there are two right next to each other and the run horizontal to the frame) that returns from the vertical radiator that splits the V is leaking a little where the shrink wrap is at, which is just over the exhaust the enters the front cylinder. I then noticed smoke coming from the area where that hose enters the radiator. I could not tell what was causing it or where it was coming from. I took the flashlight and looked into the radiator to see a stream of where the coolant had flowed right down the front of the radiator. It had collected in the bottom of the interior of the radiator cover and was leaking out the left side of the radiator when on the stand.
What gives???? I was getting ready to head to the South from Michigan (wanted to go where it was warm, the 60 degree weather sucks) with the group tomorrow afternoon for a 5 day ride through the smokey mountains and now can't because of this crap. Any ideas of what the problem is or a quick fix????
Joe
Motown_VROD
'03 V-Rod
VMod Exhaust
Screaming Eagle Air Filter
Stage One Flash
28T Pulley
Sundowner Seat
Tons of Chrome Goodies
