Originally Posted by YankeeBob
Welcome to the VTF.
Is your bike EFI or carb'ed?? What year?
All VRods are fuel injected.
Torsiello, First get a bright flashlight (NOTHING WITH A FLAME) Pop up the seat. Remove the fuel (gas) cap. Start the bike and then look inside the tank. If you see fuel spraying around like a fountain you found the problem. The fitting works its way out of the plastic flange. If this is the problem you need a special tool to remove the fuel flange. I have one I could loan you. If you need to have the dealer do it. I can give you more info to relay to them. Find out if this is the problem first. Then give us a holla back.
