Alarm Help?
Has anyone hooked up an after market siren or pager. I just got one from Thunder page that hooks up to the factory harness under the seat. I pluged it in and tested it...no chirp. I called the company to make sure I was hooking it up right and I was. He suggested I check the harness for output. Hooked up a test meter pushed the key fob, lights flashed, but no output from harness. I hot wired the siren to a 12v battery works fine. Any ideas on how to get juice to the alarm harness? I checked the wire diagram from the shop manuel not much help. any ideas?????
