.030 head gaskets : V-Twin Forum: Harley Davidson Forums
Old 09-30-2005, 11:07 AM   #1 (permalink)
Bluescb wants to know Dino or Syn?
.030 head gaskets
I read that TW37's like a little higher compression.
Will installing a .030 Head Gasket to increase compression with stock heads help the cams and be worth the effort or should I just wait till I can afford headwork? Thanks
'04 FLHRCI
95" BB
SE Flat Tops
TW37G
True Duals
Baisley
Big Sucker A/C
PCIIIusb
When I 'act my age'---shoot me
Bluescb is offline   Reply With Quote Quick reply to this message
Old 09-30-2005, 12:30 PM   #2 (permalink)
TSport_Guy wants to know Dino or Syn?
The .030 will increase about .40, so lets say your comp ratio is 9.25 to 1 with the SE flat tops, going with the .030 gaskets will get you near 9.65 to one.
Can't see how that would hurt your cam choice but more importantly it is known that the .030 squish band works well and reduces the tendency to ping.
Hope that helps.
Al
TSport_Guy is offline   Reply With Quote Quick reply to this message
Old 10-01-2005, 10:02 AM   #3 (permalink)
fatboyskip wants to know Dino or Syn?
I'm not a horsepower expert by any means but I can tell ya that it's a lot of tear down just for the gasket swap.....and then have to do it all again when you get the heads set out. If she is running fine right now, I would wait until you could do the whole enchillada at once and save the cost of a second set of gaskets and the tear down time.....unless you just like to tear things apart for the fun of it......like me!
r/ George
HARLEY DAVIDSON and The United States Navy---The Two Greatest Symbols of AMERICAN FREEDOM!!!
2002 FatBoy
95" CP Flat Tops, Cometic .030
GMR CNC Ported Heads
Andrews 37G Sticks
SE Clutch Spring
V&H Pro Pipe w/mods
GMR Lifters & Pushrods
DTT Ignition
2004 XL 883
Terminal Velocity A/C
Samson Big Guns
Mini Apes
Lowered 2 "
fatboyskip is offline   Reply With Quote Quick reply to this message
Old 10-01-2005, 12:31 PM   #4 (permalink)
'04 FLHRCI
95" BB
SE Flat Tops
TW37G
True Duals
Baisley
Big Sucker A/C
PCIIIusb
Geez with Fatboyskip, need remedial reading here. Jumped to the conclusion that you were doing this in your build, and not after. If your going to do the heads later than for sure I would make that move.
Al
Old 10-02-2005, 12:21 PM   #5 (permalink)
Thanks guys. Too much work and expense for a 2HP gain,
