1999 Road King EFI : V-Twin Forum: Harley Davidson Forums
Old 10-22-2013, 02:52 PM   #1 (permalink)
Registered User
bigskin13 wants to know Dino or Syn?
1999 Road King EFI
I am in the process of rebuilding my motor. I decided to send it out and have it up graded. I am going to 120". Worked 110" SE Heads, new jugs, Tman 625 cams, HPI 55 mm Throttle body and HD 10.5 compression pistons. D&D Boarzilla pipes. Not sure on Air Breather yet. Need to answer the question below.
The question I have is do I switch my whole EFI to Delphi, stay with Marelli EFI or go carbureted with a bored out G S&S carb.
bigskin13 is offline   Reply With Quote Quick reply to this message
Old 10-22-2013, 05:18 PM   #2 (permalink)
bodean46's Avatar
bodean46 wants to know Dino or Syn?
The MM injection will limit what kind of horsepower and torque you could make with that build. Buy the Thundermax MM replacement injection and ECM and go with the 58mm intake if you can get one. Otherwise I would do the carb.
88" 510G cams, S&S adjustable pushrods, AN Big Sucker, PCIII, Fueling oil pump, K&P Engineering oil filter, Rhineheart True-Dual headpipes with Wild Pigs with 1.75 baffles, 78.51 HP, 96.15 TQ, Dyno'd @ Doc's, St. Louis. Rebuilt to 97" BB, Woods TW5G cams, Ported heads with 1.92 intake, 1.64 exhaust valves with beehive springs. 3 Phase charging system. S&S VFI ecm, HPI 51mm throttlebody, Cobra 4" mufflers. 101hp, 103 torque.
bodean46 is offline   Reply With Quote Quick reply to this message
Old 10-22-2013, 05:43 PM   #3 (permalink)
jammer45u's Avatar
jammer45u is reading this now saying WTF is this? jammer45u is reading this now saying WTF is this?
I'd go with a carburetor.
jammer45u is offline   Reply With Quote Quick reply to this message
Old 10-23-2013, 08:17 AM   #4 (permalink)
Registered User
Thanks Guys! Guess its not a clear cut issue.
Old 10-23-2013, 08:40 PM   #5 (permalink)
01fxdx's Avatar
01fxdx wants to know Dino or Syn?
Absolutely clear. Get rid of the mm injection. Either find a carb harness or the zippers setup fo sho
107" axtel terrorist
thundertek cylinder heads
cams= not woods....
super "D"
loud d&d
2006 fltr
95" all secondhand parts
2009 1125cr. rolling grins.
01fxdx is offline   Reply With Quote Quick reply to this message
Old 10-24-2013, 12:21 AM   #6 (permalink)
JohnCA58 wants to know Dino or Syn?
I would send your HPi 55 mm back to HPi and have them convert it to Delphi injectors MM manifold TB, I am running the S.E. race tuner and Power Commander III for fine tuning. Stay with the Magnetti Marelli system and find a good dyno tuner. my set up works great. I am also running the HPi a/c. I have no problem touring in any state with fuel available. my 120 has over 20K miles and still going strong.
HPi will convert your TB to the MM TB with delphi injectors and regulator to raise fuel press. to 60 psi for lot less than buying another TB
2000 RKC HTT 120
JohnCA58 is offline   Reply With Quote Quick reply to this message
Old 10-25-2013, 08:48 AM   #7 (permalink)
dsvracer wants to know Dino or Syn?
Jim,
We can reprogram your M&M ECU to work as you want. dsv
www.danvanceracing.com
Dan Vance Racing
641 Brook Rd
Hampton Ct. 06237
FAST, NOT FICTION
Authorized S&S dealer
2001 AHDRA National Championship Pro-Gas
dsvracer is offline   Reply With Quote Quick reply to this message
Old 10-26-2013, 07:13 PM   #8 (permalink)
Fairshake's Avatar
Fairshake wants to know Dino or Syn?
I spent a lot of $$$$ about 5 years ago doing a similar build on a RK with the MM injection system. No local tuners could make the bike run like I was told it would before the build. I sold the bike with a lesson learned; I should have changed to a Delpi system or a good carb. Never Again will I modify a bike with the MM system. Later Fairshake
Fairshake is offline   Reply With Quote Quick reply to this message
Old 10-27-2013, 08:59 AM   #9 (permalink)
Don Dorfman's Avatar
Throwing the baby out with the bath water?
The MM system when coupled to a single throat TB and Delphi properly aimed injectors is very effective and easy to tune even for the guys that never evolved past PC III devices. If they can't tune the MM motor then I sure would not trust them on a Delphi bike.
I have converted them to carb before too and it works.
Old 10-27-2013, 09:33 AM   #10 (permalink)
gordonr wants to know Dino or Syn?
My father lives in Fla. One year I flew there and built his 99 RK with a 95" build for his bday. It made 105 hp 103 tq with the
Alfa-N system (MM) that was 7 years ago and about 80k down the road. Is it perfect? No but what efi for HD are? I have scheduled another trip to change his lifters. He said he would like to go Delfi and another build for bigger numbers. Go figure. Im not sure, hes going on 74.
gordonr is offline   Reply With Quote Quick reply to this message
Old 10-27-2013, 09:59 AM   #11 (permalink)
The MM system is Alpha-N and that has added simplicity but less versatility in very high compression builds. Only drawback I see for lower compression builds is the hardware is getting old.
Old 10-27-2013, 05:56 PM   #12 (permalink)
I often wonder how the baro sensor was deleted and the dual purpose map sensor was emplaced. To tell a consumer you have to shut your $18,500 bike off and reinitialize it thru altitude changes still floors me. Speed density with a baro and a lamda or oxygen sensors were well emplaced by the early eighties. Why they went the route they did I feel is they felt forced into efi and only did the minimum necessary to pass some sort of board decision. Then signed the lowest bidder.
Old 10-31-2013, 07:06 AM   #13 (permalink)
Registered User
Yes!! That is what we are doing?
Old 10-31-2013, 07:09 AM   #14 (permalink)
Registered User
I thank you all for your info. Dan we already spoke and I am in your hands. In DanVanceRacing I trust. The few people I know highly recommend you so have it!.
Old 10-31-2013, 08:07 AM   #15 (permalink)
thanks Jim. you will not be disappointed with the outcome of this project. dsv
Dan Vance Racing
641 Brook Rd
Hampton Ct. 06237
FAST, NOT FICTION
