Why does bike stink up garage after ride? : V-Twin Forum: Harley Davidson Forums
Old 02-17-2013, 09:13 AM   #1 (permalink)
luvmyUltraLimited's Avatar
luvmyUltraLimited wants to know Dino or Syn?
The last couple of months I have noticed that my bike puts off a tremendous exhaust/raw gas smell after a ride. It is so bad I can't stand to go back into the garage till the next day. I have checked for a gas leak and found none. It is fine the next day, its only right after the ride that I notice it. And, it did not used to do this, something has changed. Any ideas?
It is an 2009 FLHTC, stock except of mufflers.
luvmyUltraLimited is offline   Reply With Quote Quick reply to this message
Old 02-17-2013, 09:49 AM   #2 (permalink)
webco2 wants to know Dino or Syn?
How is the motor running?????
webco2 is offline   Reply With Quote Quick reply to this message
Old 02-17-2013, 09:52 AM   #3 (permalink)
Nitram_b4's Avatar
might be burning rich and you are getting a half burnt fuel smell
Nitram_b4 is online now   Reply With Quote Quick reply to this message
Old 02-17-2013, 09:53 AM   #4 (permalink)
guydoc77's Avatar
guydoc77 wants to know Dino or Syn?
Catalytic converter?
Bugs and bug guts decomposing?
2008 Road Glide
Phoenix Customs Bagger Brace
Glide Pro
Clearview windshield
107
CP flat tops
R&R Stage 3 heads, .030 gasket, 82cc chambers
Trued, welded, and balanced crank by Hyperformance
TMan 590 cams
SE AC
HPI 54mm TB
Supermeg with open cap and 15 discs
TTS tune by BVBob
2003 Indian Scout Deluxe
Aspen White (got it for my wife)
S&S "SuperStock" 88"
12" apes
Scary fast!
guydoc77 is offline   Reply With Quote Quick reply to this message
Old 02-17-2013, 11:12 AM   #5 (permalink)
Master Motorhead
Thermodyne's Avatar
Thermodyne just installed tassels Thermodyne just installed tassels Thermodyne just installed tassels
Well if it's not an external leak, then it gets a little hard. But an 09 should have no fuel smell sitting in the garage, the fuel system is sealed.
It could be a bad cap or a leak in the vapor recovery system. Something like a disconnected hose between the canister and tank. Or even a malfunction in the purge system. Anything been changed on the scooter that might have effected the purge system.
It could also have a leaking injector. You'll have to pull the air cleaner and open the throttle so you can look into the intake. A leaking injector will leak fuel into the hot intake after you turn the scooter off. Just a drop or two will make quite a lot of fuel smell.
Thermodyne is offline   Reply With Quote Quick reply to this message
Old 02-17-2013, 11:12 AM   #6 (permalink)
Motor runs fine, I don't notice any smell when riding, other than the usual Harley exhaust smell.
No converter.
Old 02-17-2013, 11:15 AM   #7 (permalink)
RGRider's Avatar
RGRider is still riding a stock bike RGRider is still riding a stock bike
My 2010 has done this since new if I run it into the garage hot and shut the door. My I let it cool off a little bit and all is well.
RGRider is offline   Reply With Quote Quick reply to this message
Old 02-17-2013, 11:18 AM   #8 (permalink)
Aaaahhh, I bet that's what it is, a leaking injector. That's what the smell is like, hot gasoline combined with exhaust. Thanks, Themodyne I will check that out.
Old 02-17-2013, 06:19 PM   #9 (permalink)
07heri wants to know Dino or Syn?
What does your oil smell like? If it's smelling as bad you say you might want to see if your oil smells like a ton of gas is mixed with it.
07heri is offline   Reply With Quote Quick reply to this message
Old 02-19-2013, 08:07 PM   #10 (permalink)
guydoc77's Avatar
Just realized you DID say "raw gas" smell in the original post.
I had skimmed it the other day and somehow read "garbage" and thought that was the smell you were noticing. Hence the oddball suggestions I made in the other post.
Carry on.
2008 Road Glide
Glide Pro
107
CP flat tops
TMan 590 cams
SE AC
HPI 54mm TB
TTS tune by BVBob
12" apes
Scary fast!
Old 02-19-2013, 08:36 PM   #11 (permalink)
Acquisitions
dynageno's Avatar
dynageno is reading this now saying WTF is this?
I get that raw gas smell too with my new Mikuni 42 Carb. It goes away after awhile. Don't see any leaks anywhere either, just smells a lot around the AC.
Back in Black
dynageno is offline   Reply With Quote Quick reply to this message
Old 02-19-2013, 09:14 PM   #12 (permalink)
y-2-kid wants to know Dino or Syn?
are you using oxegynated fuel [ie corn gas]?
when you shut the engine off it will heat sink and boil the fuel, it could have enough pressure in the fuel line to push the fuel past the injecters or if it has a carb it will push the fuel through the overflow and into the intake thus causing the raw gas smell
let the engine cool off a bit before putting it into the garage and quit running the cheep gas if you are
good luck
y-2-kid is offline   Reply With Quote Quick reply to this message
Old 02-19-2013, 09:44 PM   #13 (permalink)
citified wants to know Dino or Syn?
I had the same problem once, don't remember what bike, but, it needed a new gas cap.
Sent from Motorcycle.com Free App
citified is offline   Reply With Quote Quick reply to this message
Old 02-20-2013, 09:28 AM   #14 (permalink)
Can anyone tell me the proper way to check for a leaky injector? It is ok to manually open the throttle plate with my fingers? It won't seem to open any other way. Then what?
My manual says see the electrical diagnostic manual which I do not have, thanks.
Old 02-20-2013, 10:36 AM   #15 (permalink)
46u
46u's Avatar
46u wants to know where he is and how he got here
My 02 Ultra I bought new has been doing it for 92,000 miles. I just leave the garage door open for a while after riding.
6 more states and I will have them all on one motorcycle
If you see my motorcycle on a trailer call the police it was stolen!
46u is offline   Reply With Quote Quick reply to this message
