oil dip stick : V-Twin Forum: Harley Davidson Forums
Old 12-05-2012, 12:33 AM   #1 (permalink)
01HDDEUCE wants to know Dino or Syn?
oil dip stick
what's up. I have a 01 Deuce and when I start the bike recently the oil dip stick flies off and I spill oil,where am i getting this pressure from?
01HDDEUCE is offline   Reply With Quote Quick reply to this message
Old 12-05-2012, 07:13 AM   #2 (permalink)
dirtybrain is reading this now saying WTF is this? dirtybrain is reading this now saying WTF is this?
The simple answer would be too much oil. Did you recently do a "cold" oil change? If so... if that is your only symptom and your motor runs fine (i.e., its getting oil), I would get it up to running temp, then do another oil change. If you need to drain a little oil out, do it through the filler neck. I've used a bulb-type hand syphon to do it in the past. You can pick one up at the auto parts store for @ $3 and they come in handy for other applications such as syphoning fuel out of your tank when you need to replace your crossover line.
Be safe
2006 Softail Night Train
Stage I
K&N in / V&H out
dirtybrain is offline   Reply With Quote Quick reply to this message
Old 12-05-2012, 02:57 PM   #3 (permalink)
mayo73's Avatar
mayo73 wants to know Dino or Syn?
One up on to much oil...
Sent from my SGH-I747M using Motorcycle.com Free App
mayo73 is offline   Reply With Quote Quick reply to this message
Old 12-05-2012, 03:44 PM   #4 (permalink)
djl
djl's Avatar
djl wants to know Dino or Syn?
I don't know how long the bike sits between starts but a softail oil tank will leak into the crankcase if startups are days or weeks apart. Which means that if you do have more than 4 quarts of oil, you likely have oil in the tank and the crankcase on startup which will could cause crank case pressure to blow the dipstick out.
First order of business would be, as previous posts suggest, get the engine up to operating temperature and change oil; see how much comes out. If more than four quarts, you have the answer to your problem.
If 4 quarts, or less comes out, the crankcase venting system is plugged up somewhere and you will need to find the blockage and remove it.
djl is offline   Reply With Quote Quick reply to this message
Old 12-05-2012, 07:10 PM   #5 (permalink)
harley2006 wants to know Dino or Syn?
Be safe
Agree. Mine has never shot off like that on my 2006 Softail Standard. If there is to much oil, it will seep out the filler neck when it is warmed up.
harley2006 is offline   Reply With Quote Quick reply to this message
Old 12-06-2012, 02:17 AM   #6 (permalink)
Thanks to all who replied, ..
