SE 120 R 30,000 mile top end inspection : V-Twin Forum: Harley Davidson Forums
Old 11-26-2012, 07:37 AM   #1 (permalink)
strokerjlk's Avatar
27,000 miles on my 120R.
tore down for inspection. if I wasent 8-up ,I should have just bolted the heads back on and rode it another 27,000 miles.
07 ULTRA
AMRA
SE 218
DR 218
Old 11-26-2012, 07:52 AM   #2 (permalink)
HighLiner wants to know Dino or Syn?
Glad to hear no problems after 27k
HighLiner is offline   Reply With Quote Quick reply to this message
Old 11-26-2012, 09:06 AM   #3 (permalink)
guydoc77's Avatar
guydoc77 wants to know Dino or Syn?
Those narrow band sensors make for a lot less carbon build up. Impressive shape Jim.
2008 Road Glide
Phoenix Customs Bagger Brace
Glide Pro
Clearview windshield
107
CP flat tops
R&R Stage 3 heads, .030 gasket, 82cc chambers
Trued, welded, and balanced crank by Hyperformance
TMan 590 cams
SE AC
HPI 54mm TB
Supermeg with open cap and 15 discs
TTS tune by BVBob
2003 Indian Scout Deluxe
Aspen White (got it for my wife)
S&S "SuperStock" 88"
12" apes
Scary fast!
guydoc77 is offline   Reply With Quote Quick reply to this message
Old 11-26-2012, 09:19 AM   #4 (permalink)
autoworker's Avatar
autoworker wants to know Dino or Syn?
Did you v-tune it?
Motorcycle Poor
autoworker is offline   Reply With Quote Quick reply to this message
Old 11-26-2012, 12:32 PM   #5 (permalink)
lonewolf55 wants to know Dino or Syn?
Curious. What is the relationship to carbon and the type of sensor?
'07 Street Glide 107"
lonewolf55 is offline   Reply With Quote Quick reply to this message
Old 11-26-2012, 01:03 PM   #6 (permalink)
dennish's Avatar
dennish wants to know Dino or Syn?
Looks good. Nice to see there seems to be some good mileage to be gotten from these motors.
Just popped the heads off mine at 15K and sent them to Dewey's for guides, springs, port clean up and a bump up in cr. So far everything looks good also. And of course some fretting on the compensator. Don't know whether to clean it up and reinstall since it wasn't making any noise etc....
dennish is offline   Reply With Quote Quick reply to this message
Old 11-26-2012, 02:50 PM   #7 (permalink)
Don Dorfman's Avatar
At 15k yours shows guide wear and oil passing on the exhaust stems. The exhaust valves will not return to the seat unless they are not turned. Last 1/2" of the guide has baked carbon and valves show same. Not good and the exhausts were headed for seizing and pulling the guide, same as the 07 CVO heads do. Yours will be fixed with AV&V bronze manganese guides, .0014 in .0016" clearance ex and high quality viton seals. Clearances now are .0019-.0024"
Old 11-26-2012, 03:02 PM   #8 (permalink)
dennish's Avatar
Ouch, maybe not so good. Don, any obvious reason(s) for those problems? Thanks.
Old 11-26-2012, 03:13 PM   #9 (permalink)
towboattrash34 wants to know Dino or Syn?
Nothing beats a good Head job. Mmm. Never had a bad 1. Lol.
2012 CVO Ultra. And loving it !!!
06 Dyna Lowrider...Sold..Gone,but not forgotten...
towboattrash34 is offline   Reply With Quote Quick reply to this message
Old 11-26-2012, 03:37 PM   #10 (permalink)
Well for one the seals are just OK at best on a stock motor.
I am absolutely amazed that HD after the issues they had with the 110 early on would revert back to the early seal when they have a very high quality part they use on the current 110 program heads and the latest stock 110 CVO motors. They are spendy but these are expensive heads, come on guys???
At one time I was considering a "Blueprint" of the MVA head well now after confirming my worries coming true all will get new guides as do all the heads that I process here.
These exhaust valves were not rotating at all and there was the beginning of a trough on top of the stem
As far as Jims
Looks good! Proof positive and even forensically the piston and ring package works well. I know you had Larry replace your guides so no issues there.
Old 11-26-2012, 07:00 PM   #11 (permalink)
cruzmisl's Avatar
cruzmisl wants to know Dino or Syn?
Did you measure the crank run out?
cruzmisl is offline   Reply With Quote Quick reply to this message
Old 11-27-2012, 06:42 AM   #12 (permalink)
strokerjlk's Avatar
No I didn't go into the bottom end.
I have a tube of JB weld ,just in case
07 ULTRA
AMRA
SE 218
DR 218
Old 11-27-2012, 06:57 AM   #13 (permalink)
155" R&R TwinCam
dog155's Avatar
dog155 wants to know Dino or Syn?
Looking good your right, by the looks of things in the pictures that motor did not have to be torn down.Also shows you never beat on it too hard before motor was warmed up.
Now that it is down what are your plans?
dog155 is offline   Reply With Quote Quick reply to this message
Old 11-27-2012, 09:55 AM   #14 (permalink)
cruzmisl's Avatar
Jb weld works for everything lol
Old 11-27-2012, 04:33 PM   #15 (permalink)
Axe Man
BVBOB's Avatar
Yeah, why the hell did you pull it apart? inquiring minds want to know, if you only wanted to look at it you could have used a bore scope, tell us what you are up to.
1982 FXRS
80 inch
Drag pipes
SU carb
Andrews A cam
2002 Ultra Classic
127 cubic inch
Rush Wrath
custom cams
152 hp 155 tq
2016 Ultra limited.
