SE 120 R 30,000 mile top end inspection - Page 2 : V-Twin Forum: Harley Davidson Forums
Old 11-27-2012, 05:23 PM   #16 (permalink)
FNG
78738 wants to know Dino or Syn?
I think I know what he's up to *wink wink nudge nudge*
Nice crosshatch on the cylinder, did these get over sized pistons from go or are these as delivered?
78738 is offline   Reply With Quote Quick reply to this message
Old 11-27-2012, 08:13 PM   #17 (permalink)
strokerjlk's Avatar
I am pulling the cylinders.ball honing and installing a new set of std . size 12.0:1 pistons.
it all started as a weekend hop up. but I ended up having one .030 and one .040 head gasket. so I am at a stand still until I get gaskets.
I am leaving the t man 662-2 cams in ,at least for a tune.
should be cranking about 240ccp with them.
I have the RX 267 cams as well. I plan on tuning it with the Drago Fang first. then the wegner 2-1.
07 ULTRA
AMRA
SE 218
DR 218
Old 11-27-2012, 08:48 PM   #18 (permalink)
harley 103 wants to know Dino or Syn?
Jim are you TQ hunting on the left and a little extra on the right good luck on the up grade.
harley 103 is offline   Reply With Quote Quick reply to this message
Old 11-27-2012, 08:49 PM   #19 (permalink)
Don Dorfman's Avatar
Still have the 266?
Just saying..
Old 11-27-2012, 08:59 PM   #20 (permalink)
strokerjlk's Avatar
just looking for the HP ,without losing the bottom end I have now.
yes I do have the 266 still Don. if I dont like the 267 I will stick it in .
07 ULTRA
AMRA
SE 218
DR 218
Old 11-28-2012, 08:53 AM   #21 (permalink)
Premium octane member
TXCHOP's Avatar
Looking good Jim..Really appreciate your sharing info and posting it all up!
Not a lot of guys doing back to back testing like this and sharing their info.
S&S T124
Old 11-28-2012, 03:27 PM   #22 (permalink)
Procrastinator wants to know Dino or Syn?
how the heck does that not have detonation issues with 240ccp and 12:1 comp?
Procrastinator is offline   Reply With Quote Quick reply to this message
Old 11-28-2012, 03:33 PM   #23 (permalink)
FNG
I'd suggest that stroker can tune his ass off
Old 11-28-2012, 04:21 PM   #24 (permalink)
TXCHOP's Avatar
Well its not built yet, so it get good mileage too..
But yeah, Jim can tune his ass off..
S&S T124
Old 11-28-2012, 06:19 PM   #25 (permalink)
todd comer wants to know Dino or Syn?
2006 FLHXI
120"
Timken(Kirby)
SE 4.625 Crank plugged welded(Kirby)
R&R Cast heads
S&S roller rockers
T-man 662-2g cams
TTS
All Balls Starter
Oil Bud cooler
HP 55mm tb
Boarzilla
Baker DD6
todd comer is offline   Reply With Quote Quick reply to this message
Old 11-28-2012, 08:48 PM   #26 (permalink)
CowboyTutt's Avatar
CowboyTutt wants to know Dino or Syn?
-Tutt
2009 Dyna Street Bob with Ohlins/Race Tech Suspension
New mystery motor in the works
CowboyTutt is offline   Reply With Quote Quick reply to this message
Old 11-28-2012, 09:24 PM   #27 (permalink)
strokerjlk's Avatar
it very well could.
probably will be one of those that you could make ping if you wanted to try? or it could have an area or two you wouldnt want to ride in. as long as you dont ride it there,and know where its gonna ping at? your fine.
I dont think I will end up riding it with these cams in it. I dont need that kind of low end.
I was tuning it with 87 oct on the last tune. it pinged a couple times real good. I fixed it and finished tuning. that was the last wegner 2-1 tune.
so when I was done tuning the pipe back in,I pulled the top end.
if you look close at the pistons,you can see where it was detonating. looks like a chicken pecking on the carbon deposits on the top of the pistons.
if you look at the exhaust valve you can see deposits as well. if I would not have pulled the heads right after the tune,it would have blown out the pipe or got coved up with carbon.
07 ULTRA
AMRA
SE 218
DR 218
Old 11-28-2012, 11:05 PM   #28 (permalink)
INDEPENDENT 1 wants to know Dino or Syn?
I'm not sure your CCP will actually be that high. With the centerline on those cams and the overlap it should bleed off a lot of pressure. I don't think it'll be a pinger but it should be a runner!
INDEPENDENT 1 is offline   Reply With Quote Quick reply to this message
Old 11-29-2012, 06:13 PM   #29 (permalink)
rob71458's Avatar
rob71458 wants to know Dino or Syn?
I will not touch my engine this winter! I will not touch my engine this winter! Must resist!
07' FLHRSE3 124", Paul Matyka ported SE110 heads, S&S pistons/cylinders,11.5 cr, 58/62 HPI TB, 640G's, Bandit clutch, Baker DD7, IDS, 2.79 gearing, Stock Compensator, D@D Borzilla QB, K&P oil filter, Jagg ten row oil cooler, Big Sky oil cooler fans, Lenale fan, Redline oils, TWR stabilizer, Glide Pro mount. Big Boyz Tune.
rob71458 is offline   Reply With Quote Quick reply to this message
Old 11-30-2012, 07:31 AM   #30 (permalink)
TXCHOP's Avatar
You better not!!!Oh yeah, me either.
Thank God, i have a few builds for customers going on or i would have had to done something. Its just something about winter, where i have to take **** apart thats already running perfect to make it run even more perfect.
S&S T124
