113 problems : V-Twin Forum: Harley Davidson Forums
Old 11-24-2012, 08:46 AM   #1 (permalink)
REDROOSTER wants to know Dino or Syn?
113 problems
I got a 113 that I just built. Everything is brand new except the cams. screaming eagle flywheels pushrods roller rockers 11.1 pistons cnc mva heads woods tw9fg gear drives screamin eagle high flow oil pump and camplate. Now my problem motor was running fine then one day it snaped a roller rocker ARM on the exhaust side of the front cyclinder took it apart checked everything valves head everything . All good so put back together new roller rcker and took off.. all good for 150 miles and then bam intake pushrod on front cylinder blows the cover off and is bent to hell ..now I have it apart again can't find anything wrong but I know something is not right cause when I took it apart the trottle body had a lot of standing oil and I mean a lot in it. Lifters are bad now new roller rocker is toast ...checking runout today later but anyone got any ideas motor has 652 miles on it and it ran perfect for 500 miles till rocker ARM broke sorry for the long post anyhelp please and thank you
REDROOSTER is offline   Reply With Quote Quick reply to this message
