Big-bore engines : V-Twin Forum: Harley Davidson Forums
Old 11-20-2012, 06:49 PM   #1 (permalink)
rayo1 wants to know Dino or Syn?
Big-bore engines
have a 96 cu bored to a 107 & stage 4 work. is there any particular maintainance to periodically perform or double check with a big bore motor?
rayo1 is offline   Reply With Quote Quick reply to this message
Old 11-21-2012, 05:59 AM   #2 (permalink)
155" R&R TwinCam
dog155's Avatar
dog155 wants to know Dino or Syn?
Nothing needs to be focused on other than regular maintenance and keeping a good tune in the motor.
dog155 is offline   Reply With Quote Quick reply to this message
Old 11-21-2012, 03:13 PM   #3 (permalink)
does the tts tuners hold tunes pretty good. I know the old pwr commanders would drop out a lot.
Old 11-21-2012, 04:32 PM   #4 (permalink)
Ironbutt
MilesToGo's Avatar
I have a 107 build with TTS tune also. Maybe one of our resident pro tuners will chime in on this question. I would say unless you make some significant mods to your bike then your tune should hold indefinitely. At least i hopes that's the case. I sure don't want to pay another $400 to have this thing retuned. If that's the case then might as well spend the money on an auto-tuner.
Current bikes in the stable:
2009 Street Glide
2003 Heritage Softail Classic
Old 11-22-2012, 06:29 PM   #5 (permalink)
only change I have made after my dyno was going down to a 31 tooth trans pully and a 139 tooth rear drive belt. don't know if it was significant enough to need retuned but it is a definite change with the launch. Any pros or con about redynoing>
Old 11-22-2012, 09:53 PM   #6 (permalink)
Enjoying a great Ride.
jeffsglide's Avatar
jeffsglide wants to know Dino or Syn?
From what I heard,some of the bikes that were tuned years ago either with the TTS or Screaming eagle tuner are running slightly lean now due to the Quality of the Gas (ethanol) that's going in our tank. Most bikes need to be richened up about 2% to make them run right again. Quoted By Doc.
jeffsglide is offline   Reply With Quote Quick reply to this message
Old 11-23-2012, 04:55 AM   #7 (permalink)
155" R&R TwinCam
dog155's Avatar
Pull the plugs and take a peek,if they have a little color on them you will be fine,best to read fresh plugs.
Old 02-13-2013, 08:54 PM   #8 (permalink)
Had 50 miles on bike and had a big bore engine build. had the dyno at 900 miles. never really got into the bike for its worth more than 3 or 4 times now have 6500 on bike. should I get another dyno since it is well broke in?
Old 02-14-2013, 04:41 AM   #9 (permalink)
155" R&R TwinCam
dog155's Avatar
Pull the plugs and take a peek,as long as the bike runs clean and makes you happy no need for another pull.
Old 02-15-2013, 08:45 AM   #10 (permalink)
FXDRYDR is still riding a stock bike FXDRYDR is still riding a stock bike
+1
Watch for heat.
FXDRYDR
2003 FXD
124
Black, chrome & loud.
Old 02-17-2013, 01:16 AM   #11 (permalink)
big end speed drop
With 124 HP and 127 TQ, will there be noticeable drop off on the big end speedwise when going from a 32 tooth trans pulley to a 31 tooth and a shorter 139 tooth rear drive belt
Old 02-17-2013, 04:27 AM   #12 (permalink)
155" R&R TwinCam
dog155's Avatar
Not enough to worry about,you might feel a little more tug in seat of the pants.Our big inch bikes were geared up from 32 to 34 for better cruising.
This is the fun of having power like this, experimenting or in better terms dailing them in.
Old 02-20-2013, 05:29 PM   #13 (permalink)
FRANXNBEENZ wants to know Dino or Syn?
Getting back to your original question, there really is'nt any special maintainance needed for a big bore engine. The most important thing to remember is that these engines are hard on oil. Be sure to change yours regularly, and use a good filter too. Not some bargain brand.
FRANXNBEENZ is offline   Reply With Quote Quick reply to this message
Old 02-20-2013, 08:25 PM   #14 (permalink)
guydoc77's Avatar
guydoc77 wants to know Dino or Syn?
Just regular maintenance as mentioned. Nothing dramatic.
I'd add that, if you're using forged pistons, make sure you let the motor become warm to touch before you start using much throttle or getting the revs much above 1500 or so.
Does a TTS "hold a tune"?
The TTS system is not like a Power Commander. A Power Commander is installed inline between the engine's ECM and the injectors and ignition system. The "tune" is whatever is in the ECM. The Power Commander just alters the ECM's signals inline before those signals get where they're going. With a Power Commander one can make changes to the alterations that the Power Commander makes to those signals so it is a tuning device for sure.
TTS comes with a little plastic box called a dongle. The dongle is nothing more than a key to allow access to the ECM from a computer. Of course, along with the dongle, the TTS system comes with software to download onto said computer. Using the software, you can change the parameters of engine ignition timing and fueling and then download them into the ECM. When done, your ECM is reprogrammed, you unplug the dongle and ride away. There's nothing left on the bike as far as any TTS hardware, etc.
Now here's the tricky part. If you have a newer bike with oxygen sensors from the factory, then the factory tune is closed loop. When you modify your bike, you have to retune it. If you leave it in closed loop, there is a feature called "adaptive fueling" which enables the ECM to "learn" from data, good or bad, obtained, largely, from the oxygen sensors. If any of the data is "bad", which is likely to be the case in a modified engine and because the oxygen sensors are narrow band, then yes, your tune will degrade.
So, in summary:
When you modify your engine you do need to get it tuned. In my opinion an open loop dyno tune is THE most cost effective way to do that.
In order to tune the bike, you, or whoever tunes it, will need a tuning device, be it TTS or another.
2008 Road Glide
Phoenix Customs Bagger Brace
Glide Pro
Clearview windshield
107
CP flat tops
R&R Stage 3 heads, .030 gasket, 82cc chambers
Trued, welded, and balanced crank by Hyperformance
TMan 590 cams
SE AC
HPI 54mm TB
Supermeg with open cap and 15 discs
TTS tune by BVBob
2003 Indian Scout Deluxe
Aspen White (got it for my wife)
S&S "SuperStock" 88"
12" apes
Scary fast!
guydoc77 is offline   Reply With Quote Quick reply to this message
Old 02-20-2013, 08:45 PM   #15 (permalink)
DEW2112's Avatar
DEW2112 wants to know Dino or Syn?
I was under the impression that you can no longer read spark plugs like the old days due to todays fuels.
1982 SHOVEL - 96"
2002 FLHT STD
DEW2112 is offline   Reply With Quote Quick reply to this message
