Cam Delima? : V-Twin Forum: Harley Davidson Forums
Old 11-19-2012, 09:28 AM   #1 (permalink)
reinsch2001 wants to know Dino or Syn?
Cam Delima?
2000 softail, fresh 95" build, wiseco 10.5:1 pistons, heavy portwork on 07 heads, heads decked to 80cc, pistons are at .003 in the holes,.30 cometics, and s&s G carb.
My delima is... i have 3 cam sets on the bench, a TW37B, an SE-251, and an SE-257.
Not sure which will be the best for my build?? Sometimes i just cruise, and sometimes i ride hard, im looking to get some respectable #'s from this build.
Also, the cam card with the 257 shows .560 lift, everythng else i have read shows the 257 to be .569 lift, maybe i have an older grind??
reinsch2001 is offline   Reply With Quote Quick reply to this message
Old 11-19-2012, 09:35 AM   #2 (permalink)
exhaust is a V&H pro pipe, intake valves are 1.90. (if this info is helpful)
Old 11-19-2012, 02:51 PM   #3 (permalink)
Axe Man
BVBOB's Avatar
Unless you can always get good gas you can rule out the 37 with anything smaller than 82-83 cc chambers and flat top pistons. No experience with the other two in a 95
1982 FXRS
80 inch
Drag pipes
SU carb
Andrews A cam
2002 Ultra Classic
127 cubic inch
Rush Wrath
custom cams
152 hp 155 tq
2016 Ultra limited.
Old 11-19-2012, 03:07 PM   #4 (permalink)
Mohead1's Avatar
Mohead1 wants to know Dino or Syn?
251's for sure, in my opinion
BigMo
Mohead1 is offline   Reply With Quote Quick reply to this message
Old 11-19-2012, 03:08 PM   #5 (permalink)
Thats what i was thinking, im sure my ccp will be a little high with the domes and the .30 head gaskets, but the motor is built, just unsure of a good solid cam to use. Thinking of going with the S&S 585 and Ebaying the others.
Old 11-19-2012, 03:12 PM   #6 (permalink)
are the 251's proven to provide good #'s?
Also i hear they are a bit noisy??
Old 11-19-2012, 03:23 PM   #7 (permalink)
"Jane you ignorant slut!"
ceraaa42's Avatar
ceraaa42 wants to know Dino or Syn?
The engine is set up about like my Heritage 95" was when I had the 251's in it.
It had the best power band of any engine I've ridden.
I didn't have compression releases; it could have used them.
It also had some valve noise, not excessive but it was there.
Candy red sunglow
103"
SE255 cams
SE Air cleaner
Fatcat Quiet baffle
Bagger brace
43 member
ceraaa42 is offline   Reply With Quote Quick reply to this message
Old 11-19-2012, 03:26 PM   #8 (permalink)
how will the 251's work with the G carb?
Heads are set up with 190lb seat pressure at 1.8, is this too much for this cam?
Old 11-19-2012, 03:35 PM   #9 (permalink)
Dyna Ryda is reading this now saying WTF is this?
251's in a high comp 95 makes good power. They come on mid and pull all the way to rev limit.
Dyna Ryda is offline   Reply With Quote Quick reply to this message
Old 11-19-2012, 03:39 PM   #10 (permalink)
good power as in 100+tq 2500-3000 range?
Will i need roller rockers with these?
Old 11-19-2012, 03:40 PM   #11 (permalink)
Sorry so many Q's, only want to do this one time and be satisfied with the results.
Old 11-19-2012, 03:57 PM   #12 (permalink)
Mohead1's Avatar
rollers (rockers) not necessary but I believe in using them on hi-po valve trains no matter what. i used a 251 before with close to the same set up. Getting ready to try Feuling 574's, very close to the 251, with just a tad more duration and such.....give em a look
BigMo
Old 11-19-2012, 04:07 PM   #13 (permalink)
Any thoughts on the 257 cam?
Old 11-19-2012, 05:58 PM   #14 (permalink)
Axe Man
BVBOB's Avatar
I'm liking that 585 idea, do you know what the dome cc is on your pistons?
1982 FXRS
80 inch
Drag pipes
SU carb
Andrews A cam
2002 Ultra Classic
127 cubic inch
Rush Wrath
custom cams
152 hp 155 tq
2016 Ultra limited.
Old 11-19-2012, 06:13 PM   #15 (permalink)
I believe they are a 14 or 16 dome??
