If you had to fab an intake : V-Twin Forum: Harley Davidson Forums
Old 11-18-2012, 08:11 PM   #1 (permalink)
Mother's Avatar
Mother wants to know Dino or Syn?
I have to fab a intake that will mount a S&S G to the Hurricane heads. not a really tough job, but the wheels started turning in my head. Intake is going on a 124 with 11.5cr, S&S 640g's, and going in a dresser. What would you want to see as far as runner length? Plenum? Has to be within reason and out of the way of the rider's leg. I have all winter to come up with something...
Hyperformance 124ci. 11.5cr CP pistons Triple XXX S&S'G' Green filter
Wood lifters & rocker supports
R&R bottom end DT oil pump. Andrews 64G cams
Torque Inc. JWPERF.com 110 heads
DaytonaTwinTec ignition
Baker KKK/4+1 pan
RB Racing 2" 2into1Blackhole
Smith Bros. pushrods
HUGE amount of help from Torque Inc.
153hp 149tq
JWPERF.COM
Mother is offline   Reply With Quote Quick reply to this message
Old 11-18-2012, 09:17 PM   #2 (permalink)
Rollmeaway's Avatar
Rollmeaway wants to know Dino or Syn?
Eh Mother
As far as intake length goes there are various spacers available on the market these days. I have seen up to 2" but again its a tweeking procedure.
I would, if I could suggest that the intake when torqued up to the heads matches the head (intake) port without restrictions. What I mean by that is the intake inside bore matches perfectly to the bore into the intake port.
I have seen many that do not & restrict the flow of fuel to the combustion chamber.
We never even said a word,
And we rolled...
Dare...
2000 FXST - Carbed
Rollmeaway is offline   Reply With Quote Quick reply to this message
Old 11-19-2012, 05:44 AM   #3 (permalink)
Mother's Avatar
Thanks Roll, I always make sure the ports are matched up. I don't want to relocate the gas tank, but I am open to ideas as long as it's out of the rider's way...
Baker KKK/4+1 pan
153hp 149tq
JWPERF.COM
Old 11-19-2012, 07:05 AM   #4 (permalink)
frankie_b wants to know Dino or Syn?
I use a 1" spacer on my RK and there is more then enough clearance for my super G carb.
06 Road King, S&S 126 ci, D&D Boarzilla Exhaust, SA Racing Modified Super G carb, Primo Open Primary, Pro Clutch
frankie_b is offline   Reply With Quote Quick reply to this message
Old 11-19-2012, 07:30 AM   #5 (permalink)
speedfoos's Avatar
speedfoos wants to know Dino or Syn?
You guys don't put a "stumble" in the head side of the intake manifold when port matching? I've been taught to do that when port matching and PnP'ing, but are air-cooled engines different?
| PHOTOS |
speedfoos is offline   Reply With Quote Quick reply to this message
Old 11-19-2012, 08:33 AM   #6 (permalink)
gearhead
mccycle wants to know Dino or Syn?
You will probably need to move your right footrest outboard 1 inch for what you will need for a 1 spacer and 3 inch filter depth.Leg room not as good as stock but a hell of a lot better than a D carb with big filter.There could be big money for doctors to put in a offset in the riders knee area.You could take up horseback riding which also may help.
mccycle is offline   Reply With Quote Quick reply to this message
Old 11-19-2012, 08:59 AM   #7 (permalink)
Mother's Avatar
MC, I ran a 1" spacer and a hi flow Green filter with my S&S teardrop no floorboard mod no issues.
Baker KKK/4+1 pan
153hp 149tq
JWPERF.COM
Old 11-19-2012, 11:38 AM   #8 (permalink)
gearhead
Your leg is younger and much more flexible than mine. You will be in good shape for your plans then.Try to keep same dimensions as before,with as much plenum volume as you can get within these dimensions for what you want from that engine.S&S makes a nice manifold for the old STD oval port heads,I do not know if it would work ,but you may want to look at it ,as manifold leg lengths are easily altered.It has lots of stock to work internal shapes with.
Old 11-19-2012, 01:51 PM   #9 (permalink)
Don Dorfman's Avatar
The HD SE manifold is a start, then cut and fab from there.
Old 11-19-2012, 03:07 PM   #10 (permalink)
disco wants to know Dino or Syn?
Fab up something that makes it impossible to draw hot air off of the cooling fins. All engines have a huge HP derate based on intake air temperature (not to mention preignition problems). This is next on my list of fab projects.
The man on the grassy knoll.
disco is offline   Reply With Quote Quick reply to this message
Old 11-19-2012, 03:35 PM   #11 (permalink)
FNG
78738 wants to know Dino or Syn?
I'd start with the filter. Get a list of dimensions from K&N, then go from there. Calculated length wouldn't be hard to figure out, I understand the formula Vizard came up with is very good; as an aside, I suspect that there are very few HDs tuned to the second or even third harmonic. For the second harmonic the calculated length, from memory, was close to 2" at 6500rpm.
78738 is offline   Reply With Quote Quick reply to this message
Old 11-19-2012, 05:15 PM   #12 (permalink)
Premium octane member
TXCHOP's Avatar
Thats the only/best way imho..Played with spacing a ton back in my carb days. Never seen a result worth the effort.
S&S T124
Old 11-19-2012, 11:23 PM   #13 (permalink)
Mother's Avatar
thanks Dan!
Baker KKK/4+1 pan
153hp 149tq
JWPERF.COM
Old 11-20-2012, 02:54 AM   #14 (permalink)
torqueinc's Avatar
torqueinc wants to know Dino or Syn?
Still think you should try the Ultima oval port intake
torqueinc is offline   Reply With Quote Quick reply to this message
Old 11-20-2012, 03:54 AM   #15 (permalink)
Gearhead
2wheelrider's Avatar
2wheelrider wants to know Dino or Syn?
I managed to to put a mikuni 48 on my 126. I was dead set on having one. I had to raise the tank 3/4" at the and use a 1" adapter spacer plus one of the adapters that bolts up to the back of a mikuni for S&S two bolt flange. Motorway engineering makes them.
2001 FLHTC 95ci Custom mtr hyd cam & 06up heads
welded btm & forged pistons to much to list. for sale.(SOLD)
2001 FXDXT (S&S SA 131ci motor)
2010 street glide..103ci 57 cams...fun and reliable...
2wheelrider is online now   Reply With Quote Quick reply to this message
