Dies out-Idles races : V-Twin Forum: Harley Davidson Forums
Old 11-04-2012, 04:11 PM   #1 (permalink)
freebee wants to know Dino or Syn?
I have a stock except (slip-ons) 2009 FLHTCUI, 25,000mi. Had a PC-V and SE breather, I returned it to stock condition as a process of elimination..No help
Within the last week It's started to have an intermittent problem nearly every time I ride. When warmed up and cruising it will die for less than a second, the speedo will drop to zero then return to actual speed.
After this occurs the idle is very high 2,000 -2,500. there are no engine lights or unusual security lamp behavior.
It appears (to me) to be electrical the Batt. less than 3mos. old, I cleaned and tightened the connections. I cleaned the TB connection harness and used Dielectric grease a few months ago, after reading about it on here.
Codes:
P none
S b1123, B1124
S none
P none
t b1006
b no r sp
Any thoughts before I make a trip to the dealer to have it diagnosed ?
Thanks in advance !
FREEBEE
freebee is offline   Reply With Quote Quick reply to this message
Old 11-04-2012, 05:34 PM   #2 (permalink)
speedfoos's Avatar
speedfoos wants to know Dino or Syn?
Sounds like a vacuum leak to me. Did you bump a vacuum line on the intake?
| PHOTOS |
speedfoos is offline   Reply With Quote Quick reply to this message
Old 11-04-2012, 05:54 PM   #3 (permalink)
webco2 wants to know Dino or Syn?
Check the main wiring harness connectors under the seat . I had that problem on a '05 FLHTCUI and it was because of connectors not making good contact.
webco2 is offline   Reply With Quote Quick reply to this message
