Looking for 117 pistons and jugs - Page 2 : V-Twin Forum: Harley Davidson Forums
Old 11-03-2012, 02:24 PM   #16 (permalink)
Don Dorfman's Avatar
Andy we are on the same page but we can talk those theories until the cows come home and I agree these factors are all relevant but really when a motor is engineered as as assembly by compentent mechanical engineers that have access to tools equal to or better than than OEM (read between the lines S&S) they result works, usually, there is a high probability of success lets just say. I know of many S&S 124" motors with higher miles that run every day, no screwing around. They will make 130 out of the box or more with just ahead mill. Variants of the 120r are right there too.
Then an end user takes well engineered parts and creates their own version of something that is supposed to be the street sweeper of all time and what happens? IME and what I have observed after being on these forums since 2001 usually anything from poor to fair results most of the time and then occasionally a home run. Considering the effort involved to be different and the money invested one has to wonder if it is really worth it?
Old 11-03-2012, 03:14 PM   #17 (permalink)
CowboyTutt's Avatar
CowboyTutt wants to know Dino or Syn?
Don, from what I have been reading, there are a lot of milling and clearances that need to be checked with a 124" and I would agree I think I would only use a well established kit like the S&S or someone who is VERY familiar with making larger cubic inch engines. I can see how if you keep the redline at an appropriate level that a 4 5/8ths crank assembly should be OK. I myself would not choose to reinvent the wheel and would start with a combination that is pretty well proven. However, Mother is used to a high rpm build and the 124 probably isn't because it doesn't NEED to be!
I think Mother might be happier with the shorter stroke of the 117 myself and its higher rpm ceiling.
Thanks as always for your input. I think for me someday I will stick to my tentative plan to make mine a 107 with some simple upgrades as I'm very happy with what I have. It doesn't seem to over-stress my stock transmission and driveline (I did seriously upgrade the clutch however!).
Thanks! -Tutt
2009 Dyna Street Bob with Ohlins/Race Tech Suspension
New mystery motor in the works
CowboyTutt is offline   Reply With Quote Quick reply to this message
Old 11-03-2012, 03:19 PM   #18 (permalink)
INDEPENDENT 1 wants to know Dino or Syn?
Dead on right, Don. Trying to be different can turn into a science project. I think the S&S 124 is THE way to go with all the amenities it comes with and the warranty to boot. Of course this is just my opinion on the two choices posed here.
INDEPENDENT 1 is offline   Reply With Quote Quick reply to this message
Old 11-03-2012, 04:54 PM   #19 (permalink)
CowboyTutt's Avatar
What do people typically set their redline to on a S&S 124" build? There is usually some recommended standard. For example, most people with 103 and 107's typically use 6250 as a limit. Mine is 6300 and sees it pretty regularly and my engine runs out of breath beyond that so no need to go further.
I appreciate the intelligent dialog on the subject here and not the derisive innuendo that takes place on the HTT forum. I guess people are just better behaved over here.
Thanks.
-Tutt
Old 11-03-2012, 05:38 PM   #20 (permalink)
Mother's Avatar
Mother wants to know Dino or Syn?
..I have been wrenchin for 25 years and I understand that a 4", 4 3/8", and a 4 5/8" stroke have different rpm ceiling.
Andy youre right, I am on the fence between 117 and 124. The reason? Working rpm range!
Hyperformance 124ci. 11.5cr CP pistons Triple XXX S&S'G' Green filter
Wood lifters & rocker supports
R&R bottom end DT oil pump. Andrews 64G cams
Torque Inc. JWPERF.com 110 heads
DaytonaTwinTec ignition
Baker KKK/4+1 pan
RB Racing 2" 2into1Blackhole
Smith Bros. pushrods
HUGE amount of help from Torque Inc.
153hp 149tq
JWPERF.COM
Mother is offline   Reply With Quote Quick reply to this message
Old 11-03-2012, 05:44 PM   #21 (permalink)
CowboyTutt's Avatar
Thanks Bro! I appreciate it!!! Nice to know I'm not alone out here. -Andy
Old 11-03-2012, 06:04 PM   #22 (permalink)
CowboyTutt's Avatar
Now about that lightened crank assembly for more responsiveness.....
Your friend
-A-
Old 11-03-2012, 06:30 PM   #23 (permalink)
You can run the pork chop flywheels but you're splitting hairs here. You'll pay for that extra tenth it might shave off your 1/4 mile time.
How tight you wind it comes down to how you set up the valve train. Throw in some good lifters, heavy springs and a set of .165 wall pushrods and rev it to 7 grand.
Old 11-03-2012, 06:41 PM   #24 (permalink)
CowboyTutt's Avatar
Couldn't care less about the 1/4 mile time. I'm no drag racer. Roll on acceleration does matter to me however as I'm a "reformed" sport bike guy who bought a Harley and never looked back. For most people, it would not be beneficial but for me and my small 103 or 107 some day, it would be. -Tutt
Old 11-03-2012, 07:13 PM   #25 (permalink)
strokerjlk's Avatar
outside of the box ? All bore 120
4" stroke 4.375 bore 8 " rod. Hurricane heads.
07 ULTRA
AMRA
SE 218
DR 218
Old 11-03-2012, 07:18 PM   #26 (permalink)
CowboyTutt's Avatar
Dear Jim, might be a bit much on the bore! What you got for a recommendation with a 4.25 stroke and what bore? What cases? Mine is sadly an 09 TC. I am listening! -Tutt
Old 11-03-2012, 07:25 PM   #27 (permalink)
delete.........
Old 11-03-2012, 08:01 PM   #28 (permalink)
CowboyTutt's Avatar
Independent one, I appreciate your comments. Maybe just PM me if your more comfortable.
Regards,
-Tutt
Old 11-03-2012, 08:10 PM   #29 (permalink)
strokerjlk's Avatar
I dont have any idea who makes a 4.250 crank for a T/C
And I think that R&R heads run cooler too.
Cooler than what? come on tutt,you know better than that.
next thing you know ,someone will say they spool up faster too.
07 ULTRA
AMRA
SE 218
DR 218
Old 11-03-2012, 08:11 PM   #30 (permalink)
Thanks, Cowboy. Just not sure what to say here, this thread/build seems to be a little all over the place. I guess we'll see where it goes from here. On another note, I did get a Fang pipe in earlier today. Now I'm waiting on the engine and throttle body. Good luck with your build, Mother. Let us know how it turns out.
