Axtell-bypass-system - Page 2 : V-Twin Forum: Harley Davidson Forums
Old 10-26-2012, 12:45 PM   #16 (permalink)
djl
djl's Avatar
djl wants to know Dino or Syn?
Originally Posted by strokerjlk View Post
cooler oil because it is bypassed into the cam chest and returned to the tank before it is sent to the top end again. the stock bypass seats, on the cast surface of the camplate. now there is a hardened seat with the insert. idle oil pressure has been reported to be 12-16 psi. with cruise pressure the same or slightly lower.32-38 psi.
OK, did a little more reading and now have a clear understanding of what the diverter does. Seems that if the hardware is priced right, the diverter would be an upgrade to the OEM system and a worthwhile addtion to any TC motor, regardless of configuration.
When will the diverter be available?
djl is offline   Reply With Quote Quick reply to this message
Old 10-26-2012, 01:00 PM   #17 (permalink)
strokerjlk's Avatar
Available now. I was told back when the prototype were tested , I would get one of the first production run to try. So I haven't had a chance to talk to them , but mine was shipped when they came in , so I assume the first shipment arrived . If they haven't sold out yet they should have some available now.
07 ULTRA
AMRA
SE 218
DR 218
Old 10-27-2012, 09:53 AM   #18 (permalink)
Gearhead
2wheelrider's Avatar
2wheelrider wants to know Dino or Syn?
How much does this bypass system cost now that I realize I must have one.
2001 FLHTC 95ci Custom mtr hyd cam & 06up heads
welded btm & forged pistons to much to list. for sale.(SOLD)
2001 FXDXT (S&S SA 131ci motor)
2010 street glide..103ci 57 cams...fun and reliable...
2wheelrider is offline   Reply With Quote Quick reply to this message
Old 10-27-2012, 10:46 AM   #19 (permalink)
rob71458's Avatar
rob71458 wants to know Dino or Syn?
$58.50. For more info, click on the link, just above Stroker's sig. line, on post #1.
07' FLHRSE3 124", Paul Matyka ported SE110 heads, S&S pistons/cylinders,11.5 cr, 58/62 HPI TB, 640G's, Bandit clutch, Baker DD7, IDS, 2.79 gearing, Stock Compensator, D@D Borzilla QB, K&P oil filter, Jagg ten row oil cooler, Big Sky oil cooler fans, Lenale fan, Redline oils, TWR stabilizer, Glide Pro mount. Big Boyz Tune.
rob71458 is offline   Reply With Quote Quick reply to this message
Old 10-29-2012, 12:55 PM   #20 (permalink)
Burch753 wants to know Dino or Syn?
got mine in the mail on friday! cant wait to try her out... I may be upgrading to the thayer stage 3 pump as well.... on the fence on this decision, but I figure it wont hurt with the B2 headed addition...
2009 RK "black betty"
124"
S&S parts
Constantly under revision...
Burch753 is offline   Reply With Quote Quick reply to this message
Old 10-29-2012, 01:25 PM   #21 (permalink)
strokerjlk's Avatar
Pulled the trigger on the b2 's
07 ULTRA
AMRA
SE 218
DR 218
Old 10-29-2012, 01:45 PM   #22 (permalink)
FNG
78738 wants to know Dino or Syn?
You did? For the bagger? Siiick
78738 is offline   Reply With Quote Quick reply to this message
Old 10-29-2012, 03:42 PM   #23 (permalink)
strokerjlk's Avatar
No not me. Burch
07 ULTRA
AMRA
SE 218
DR 218
Old 10-30-2012, 11:00 AM   #24 (permalink)
Shh.... I'll keep everyone posted as the project moves forward.
124"
S&S parts
Old 11-01-2012, 02:38 PM   #25 (permalink)
Tribal wants to know Dino or Syn?
I'm getting a bypass valve to try. Going into an R&R camplate. My 408G cam is a rattler....who knows it this will tame the noise.
Tribal is offline   Reply With Quote Quick reply to this message
Old 11-01-2012, 06:55 PM   #26 (permalink)
Don Dorfman's Avatar
Certainly poses the "acid test" if this device purports to help reduce valve train noise. Please report your results and be sure to have the oil just as hot as it was when sampling previously.
Old 11-01-2012, 07:02 PM   #27 (permalink)
todd comer wants to know Dino or Syn?
Purchased one for my winter project. Spoke to Axtell and it sure makes sense,time will only tell. Hope this does not turn out like my Nikasil cylinders!!!
2006 FLHXI
120"
Timken(Kirby)
SE 4.625 Crank plugged welded(Kirby)
R&R Cast heads
S&S roller rockers
T-man 662-2g cams
TTS
All Balls Starter
Oil Bud cooler
HP 55mm tb
Boarzilla
Baker DD6
todd comer is offline   Reply With Quote Quick reply to this message
Old 11-12-2012, 07:55 AM   #28 (permalink)
I installed the Axtell bypass in my Road King Sunday; very happy with the significant reduction in noise. It is a shorter part designed to work with an R&R camplate. I’m using a 408G and while it is a great performance cam, the I consider the valve train noise embarrassing. Took about 3 hours to install the valve. Had to remove floorboards, and Boarzilla to get to the cam chest cover. I left the camplate on the bike. Biggest hassle was getting the old valve out of the camplate. Bore was deformed at the roll-pin hole. The valve hung-up on the roll-pin hole. I didn’t have the right size drill, so I used the Axtell valve/cartridge to de-bur the hole. Then I pulled the lower front pipe plug and used compressed air to push the old valve out. There’s still some valve train noise, however the noise that sounds like misadjusted solid lifters is gone.
Old 11-19-2012, 12:12 AM   #29 (permalink)
strokerjlk's Avatar
I got mine in.
I went from 4-5 psi at idle to 11-12 psi now.
top end noise is way better. its as quiet as I have ever heard it.
07 ULTRA
AMRA
SE 218
DR 218
Old 11-19-2012, 12:46 AM   #30 (permalink)
aubeagle wants to know Dino or Syn?
This is good news iam glad that its working for you guys. Iam gonna get one for my SE camplate. My cams do make some noise but not much. Seems to me any improvment with the oiling system be it our V-Twin or whatever we drive or ride is a step in the right direction. Thank you for posting your results and pictures..
S.
04 FXDLI
SE113
Dan Vance
Ported MVA's
Crane 296-2
Woods lifters
SE Roller Rockers
HPI 55 tb
Marren 5.3
Injectors
VH Propipe
T/max
aubeagle is offline   Reply With Quote Quick reply to this message
