S&S 124 2007+ new build + minor mods : V-Twin Forum: Harley Davidson Forums
Old 10-09-2012, 05:40 PM   #1 (permalink)
We are installing one in a 2011 bagger.
Beehive springs = reduce a slight bit of seat PSI and major nose PSI
Increase comp ratio from 10.8 to 11.2
Minor port work ( heads are as cast from S&S)
66 MM Hog FBW & S&S muscle air cleaner
EX currently is a V&H T dual with HO mufflers ( may be changed)
Bandit clutch
Baker DD7 trans
Baker chain tensioner
Baker HD throw out bearing kit
Baker HO primary bearing kit.
The last one we did as a crate engine went 136/138 Looking to put this one into the mid 140's on both HP/TQ.. Parts are on the way will post up results when done..
Old 10-09-2012, 05:47 PM   #2 (permalink)
Premium octane member
TXCHOP's Avatar
I think its gonna be a home run.
Gotta love a guy that does it once and right. Adressing the motor/trans and primary all in one shot.
S&S T124
Old 10-09-2012, 05:54 PM   #3 (permalink)
plongson's Avatar
plongson wants to know Dino or Syn?
Sounds like a "Money is no object" build...And on an at least, $25k bagger.
Don't get me wrong, I'd be there in a heart beat, but...you know what I'm sayn'
I guess I'm envious!
On the road again...
plongson is offline   Reply With Quote Quick reply to this message
Old 10-09-2012, 06:07 PM   #4 (permalink)
Burch753 wants to know Dino or Syn?
sounds like I'm headed in a similar direction per some in-depth converstions! anxious to see what she makes and where.
2009 RK "black betty"
124"
S&S parts
Constantly under revision...
Burch753 is offline   Reply With Quote Quick reply to this message
Old 10-09-2012, 09:00 PM   #5 (permalink)
jam65's Avatar
jam65 wants to know Dino or Syn?
And as soon as these crates show their stuff,the B2 option will have some people foaming at the chops.
jam65 is offline   Reply With Quote Quick reply to this message
Old 10-10-2012, 12:12 AM   #6 (permalink)
Fixuntilbroke wants to know Dino or Syn?
Sounds like you already have a pretty good setup why do you want to change?
2003 Superglide
124"
Baisley Hybrids
Bored G w/T jet
640 Easy Starts
Borzilla
Rivera Primo
R&D Transmission
Chain Conversion
Always a list of breaking or broken parts
Fixuntilbroke is offline   Reply With Quote Quick reply to this message
Old 10-10-2012, 10:18 AM   #7 (permalink)
Well I have a 120R that I built for my own bike sitting on the bench.. Been riding so waiting for some down time to drop it in.. Then the 124 SS engines are making good power in crate form, I am thinking about pulling the 120R apart and dropping on a larger cylinder, and the B2 heads for my own bike... Gets me thinking..
The B2 items are getting so much eaiser to install with the bolt on FBW t/b, RB racing making a pipe, etc....
Old 10-10-2012, 10:27 AM   #8 (permalink)
Bad Disposition's Avatar
Bad Disposition wants to know Dino or Syn?
Git er done!
08 ULTRA /120 CC Mutt
4.060" big-bore cylinders.
4-5/8" stroke S&S Flywheels
Compression 10:7
T-Man 660SM
R&R Roller Rockers
S&S Lifters (HL2T with limters).
R&R Stage IV CC Heads
HPI 55 mm Throttle Body/1.800 intake
HPI Injectors
Evolution Diamond Terminator Clutch Basket
Bandit Sportsmen Clutch
Bassani Road Rage 2:1 Header
Dyno 143hp/142tq
Bad Disposition is offline   Reply With Quote Quick reply to this message
Old 10-10-2012, 11:04 AM   #9 (permalink)
Always room for improvement! I'm never satisfied....
124"
S&S parts
Old 10-10-2012, 11:23 AM   #10 (permalink)
zeus0909 wants to know Dino or Syn?
is this new enough that its not shown online yet?
zeus0909 is offline   Reply With Quote Quick reply to this message
Old 10-10-2012, 01:37 PM   #11 (permalink)
HighLiner wants to know Dino or Syn?
Sounds like fun!!!
HighLiner is offline   Reply With Quote Quick reply to this message
Old 10-19-2012, 10:04 AM   #12 (permalink)
Well engine showed up later after noon.. Trans will be here end of next week.. I will get some pics posted as we pull the engine down.. .. There will not be huge things done, basic items more so..
Old 10-20-2012, 08:29 PM   #13 (permalink)
cllsr's Avatar
cllsr wants to know Dino or Syn?
Bandit clutch
Baker DD7 trans
Steve,
Is this the one that the tranny bearing was in pieces that you showed me?
Should be very stout build.
2016 FLTRUSE CVO Road Glide Ultra
Ruby Red & Palladium Silver
cllsr is offline   Reply With Quote Quick reply to this message
Old 10-22-2012, 09:47 AM   #14 (permalink)
Yes it is... Customer I am sure will be very pleased with the final product.
Old 10-25-2012, 04:16 AM   #15 (permalink)
chriscalabro's Avatar
chriscalabro wants to know Dino or Syn?
Can you tell me whose lifters your going with in this? Also comment on the Baker chain tensioner
2007 HD FLTR (Road Glide)
R&R 131 Build
R&R Stage V billett Heads
S&S 640 Cams
R&R Billet 131 Jugs
Bassani Road Rage
HPI TB 62 MM
Baker DD7
Baker +1
SE Performance Comp
(1) Jagg Oil coolers
Michelin E3 Rubber
Rivera Pro Clutch Hydraulic
chriscalabro is offline   Reply With Quote Quick reply to this message
