Harley newb needs cam selection help : V-Twin Forum: Harley Davidson Forums
Old 10-03-2012, 09:18 PM   #1 (permalink)
flyin wants to know Dino or Syn?
Bike is a 2012 FLD.
Stock 103"
Power Commander 5
Arlen Ness Big Sucker I
Rush Racing 2>1
The motor has 2400 miles on it.
I am keeping the heads stock for now.
I would like to go to a .030 MLS head gasket if possible for better quench and a bit more compression.
I shift at redline (where ever that may be). So if the cams you recommend make power on the right side of the curve, I am ok with that as the rpm drop between shifts is where I need to make power besides 1st gear "launch"
flyin is offline   Reply With Quote Quick reply to this message
Old 10-04-2012, 04:13 AM   #2 (permalink)
59panhead wants to know Dino or Syn?
call Andrews products in IL or look @ there website!
stock heads will narrow your choices but you will still gain power & torque Cam choice is always determiend by how the heads flow! stock heads are junk and are the main reason the newer motors run so hot....with the right mods they can run 30-40% cooler
call Randy @ Hyperformence kingofcubes.com
59panhead is offline   Reply With Quote Quick reply to this message
Old 10-04-2012, 06:37 AM   #3 (permalink)
strokerjlk's Avatar
Originally Posted by flyin View Post
Bike is a 2012 FLD.
Stock 103"
Power Commander 5
Rush Racing 2>1
Cycle Rama 575
SE 204
Andrews 57
Andrews 54
Fueling 574
The heads have nothing to do with the heat issues.
The. Cams having no overlap , and the EPA mandated lean closed loop fuel management is what makes them run hot.
Any of these cams should get you in the 90-95 hp 105-115 tq range .
The curve wll be slightly diff depending on the cam choice.
The cycle Rama 575 andrews 57,SE 204 will come on a little quicker , and the feuling and Andrews 54 will come on a little later.
On a dyna you could give up a little low end grunt to gain on the top.
Cycle Rama 575 works sweet .
07 ULTRA
AMRA
SE 218
DR 218
Old 10-04-2012, 01:17 PM   #4 (permalink)
rcsoftail wants to know Dino or Syn?
Just did a 103" bagger a few weeks ago. Put in a .030 mls head gasket and andrews 57h cam. Left the stock push rods and tubes. No dyno number, but seat of the pants feel was very good. A lot of bang for the buck.
rcsoftail is offline   Reply With Quote Quick reply to this message
Old 10-10-2012, 10:25 PM   #5 (permalink)
rjd
rjd wants to know Dino or Syn?
I'm still a newb, but I used the TW222 cams and I'm very pleased.
rjd is offline   Reply With Quote Quick reply to this message
Old 10-14-2012, 04:44 PM   #6 (permalink)
SteveB wants to know Dino or Syn?
In 2006 the heads were changed, at least for Dynas, they flow better than many previous hi-po heads. Fuel injection does not like overlap cams, they pollute the charge. Check automobiles current state of tuning. I could be a few years behind on that.
2006 FXDL
0.0315 squish out the door when new
H-D "Custom" windshield
H-D Passenger backrest and luggage rack
Doherty PowePacc Kit with crank vents
Cobra fi2000 O2
H-D oil cooler
Synthetic oil
Patriot Defender exhaust
dunlop 401F
Michelin Commander II rear
XLC handlebars and 2" extra rise in Risers
10.5" shocks
1" lowered seat with memory foam added
Chrome
Superchips Vigilante
SteveB is offline   Reply With Quote Quick reply to this message
Old 10-15-2012, 02:24 PM   #7 (permalink)
Slick03 H-D's Avatar
Slick03 H-D wants to know Dino or Syn?
I'm looking to try the Tman 555 Torqster cams in my new motor after I get a few hundred miles on it, with the Cometic 0.30 head gaskets and adjustable pushrods, and check and set the deck on the heads.
2013 110th anniv dark bronze metallic & black bagger.
107 motor, heads by V Twin Perf. T-Man 625 cams
Drago's Dragula 1, 2 into 1 pipe with 2.55 baffle
H-D Ventilator air cleaner, Dyno by Doc/115hp & 120tq
CVO adjustable rear shocks
Leather C&C seat
Freedom 8" dark smoked windshield
Painted inner fairing & Fat Boy frt fender
Streamliner boards/pegs
Nostalgic bag rails
10" Yaffe mini apes
More to come much to my wife's dismay
Slick03 H-D is offline   Reply With Quote Quick reply to this message
Old 11-08-2012, 11:28 PM   #8 (permalink)
I went ahead and purchased a set of the Cycle Rama 575's!
Thanks all for your input!
Old 11-08-2012, 11:39 PM   #9 (permalink)
windwolf's Avatar
windwolf wants to know Dino or Syn?
I know you probably won't want to hear this, but you are asking for trouble if you run the "C" lifters that come with the bike. They can hardly stand the stock cams and will self destruct with anything bigger.
I'd highly recommend you change out lifters to S&S lifters, set them down the hole .140. IMHO the best of the rest! windwolf
windwolf is offline   Reply With Quote Quick reply to this message
Old 11-09-2012, 01:39 AM   #10 (permalink)
Scootin wants to know Dino or Syn?
Agreed! If u do cams, you need to swap the stock lifters and it would be a good idea to get new cam bearings (around $20bux), amd adj. pushrods IMHO, this will make it all easier down the road
Jared
2012 FXDWG
Scootin is offline   Reply With Quote Quick reply to this message
Old 11-09-2012, 02:42 AM   #11 (permalink)
Fred1369 is still riding a stock bike Fred1369 is still riding a stock bike
Head-Quarters 575 cam and Black Ops lifters. Pulls all the way from 2000 to 6000 . Shift anywhere you want. Awesome.
Fred1369 is offline   Reply With Quote Quick reply to this message
Old 11-09-2012, 12:42 PM   #12 (permalink)
So the general consensus is the is no true "bolt in" cam?
lifters at minimum,and pushrods should be done.
