What would you do with a new 103? : V-Twin Forum: Harley Davidson Forums
Old 09-17-2012, 01:35 AM   #1 (permalink)
Dyna Ryda is reading this now saying WTF is this?
One of my really good friends just sold his 03 fatboy, that had a nice 107" that I built, think it made 110/117 if I remember right. He bought a 2013 road king and he wants me to "hook up the motor". I am thinking exhaust, a/c, tuner. and cams, maybe head work and shave'em down for a little more compression. So what would you guys do, what cams, pipe, a/c, etc.... he likes to twist the throttle and is not scared to wind it out. I'm thinking, leave the pistons and cylinders (they are new, and already 103")pull the heads for cnc port and bigger intake valve and fly cut for compression, cams????not sure, looking at something like s&s 585, input?
Dyna Ryda is offline   Reply With Quote Quick reply to this message
Old 09-17-2012, 01:59 AM   #2 (permalink)
C-Cat wants to know Dino or Syn?
Sounds like the buld and your friend might benefit from a forged piston. I bought a hold over 2011 96in. just for the fact I wanted forged pistons when I had it built. So if I was swapping them out I didn't need the 103, saving some money in the process.
124 ci. 07 Streetbob
107ci. 2011 RGC
C-Cat is offline   Reply With Quote Quick reply to this message
Old 09-21-2012, 11:46 AM   #3 (permalink)
I completly agree on the forged piston vs cast junk pistons. But they are brand new and should be ok for the first build. I will keep the ccp below 190 and limit the rpm to 6000 then they should hold up ok.
Anyone here have a new 103" that has been modified? What cams and other work did you do and how do you like it?
Old 09-21-2012, 11:53 AM   #4 (permalink)
strokerjlk's Avatar
Bang for the buck? Throw a cam, exhaust , tune on it .
Just finished Frankie b's 103 with a cycle Rama 575. It didn't lose anything down low, and from 2600 up it just flat gained
There are several cams that work good in them.
Could he live with 90-95 hp 105-115 tq, ( exhaust dependent )
07 ULTRA
AMRA
SE 218
DR 218
Old 09-21-2012, 12:00 PM   #5 (permalink)
zeus0909 wants to know Dino or Syn?
Did a fueling 574 intake and thunder header 2 into 1 on mine and it reacted very well to that combo
zeus0909 is offline   Reply With Quote Quick reply to this message
Old 09-21-2012, 12:02 PM   #6 (permalink)
Haven't had it on the dyno yet because I've decided to get some head work done, but even with a canned map it is impressive
Old 09-22-2012, 01:49 AM   #7 (permalink)
Ando wants to know Dino or Syn?
Just did a mate new softail, we put the RS575 cams, decked heads 82cc, 1.9 intake no porting and it did 99HP and 110 Torque
its fun to ride
Ando is offline   Reply With Quote Quick reply to this message
Old 09-23-2012, 07:50 PM   #8 (permalink)
0ldhippie's Avatar
0ldhippie wants to know Dino or Syn?
If ya are flowing the heads and going bigger cams it's better do some 10.5 or so forged pistons than cutting the heads. If ya don't do the heads, look at the new andrews 57h?
Retired and living off the interest on the money I owe.
0ldhippie is offline   Reply With Quote Quick reply to this message
Old 09-24-2012, 12:39 AM   #9 (permalink)
sgmfisher wants to know where he is and how he got here
If it's new, what's wrong with just riding it untill it breaks down or dies of old age??? Some people have more money than sense. In the wind.
Pops
sgmfisher is offline   Reply With Quote Quick reply to this message
Old 09-24-2012, 09:56 AM   #10 (permalink)
Larbaldi's Avatar
Larbaldi wants to know Dino or Syn?
+1 on what "strokerjlk" says ... Yep .... This is the best bang for your buck !!
Black Bikes Matter
2009 FLHTCU ( BLACK, OF COURSE ! )
1979 FXEF STROKER ( BLACK, OF COURSE ! )
BUSHTEC QUANTUM TRAILER ( BLACK, OF COURSE ! )
AMA MEMBER / ABATE MEMBER
Larbaldi is offline   Reply With Quote Quick reply to this message
Old 09-24-2012, 01:24 PM   #11 (permalink)
rcsoftail wants to know Dino or Syn?
Just converted a 96" to 103". Used a set of pistons from a factory 103" and bored the cylinders out. Pistons were .010 down below cylinder surface, so used .030 head gaskets. Used an Andrews 57h cam with factory push rods. No head work. Very impressive seat of the pants results for a very low cost build. Definately much stronger than the factory 103's I have ridden.
rcsoftail is offline   Reply With Quote Quick reply to this message
Old 09-24-2012, 11:28 PM   #12 (permalink)
DURWOOD's Avatar
DURWOOD wants to know Dino or Syn?
Here's what I did on my 103 at 920 miles.The sheets are in this thread.
http://www.v-twinforum.com/forums/tw...upgrade-2.html
2011 Road glide Ultra
John 3:16
DURWOOD is offline   Reply With Quote Quick reply to this message
Old 09-24-2012, 11:33 PM   #13 (permalink)
Pops
what's the fun in that? This is the twin cam PERFORMANCE section.
Old 09-24-2012, 11:42 PM   #14 (permalink)
I read that thread as you guys were doing it. Very impressive for what was done but we don't have a dyno tuner as good as stroker out here. Unless stroker is planning a winter vacation to Hawaii I need to look at cams and heads that will be easier to tune.
I'm looking for a cam in the 570-600 lift with a intake duration of 240-250. Something that hits hard in the middle and pulls all the way through. I'll have the heads done and cut for the right compression.
I know there are people making 120 hp/tq out of 103", we're not looking for that right now. Maybe 105/110 because of the cast pistons. I might talk him into ditching the stock slugs and going for a set of cp's and bumping up to a 107, not sure yet. It's kinda like where do you stop. If we make it a 107 then we need a new throttle body, injectors, clutch, etc etc etc....
Old 09-25-2012, 05:35 AM   #15 (permalink)
Outsider
Half_crazy's Avatar
Half_crazy wants to know Dino or Syn?
Sell the engine on ebay and replace it with a reliable and potent crate motor?
2006 Victory Kingpin
116 Cubic Inches -- Balanced S&S crank/rods, Lloydz iron liner big bore, 11:1 Wiseco pistons, massaged
stock heads, stock throttle bodies/injectors/intakes, S&S .495 cams/springs/retainers, Torque Tubes
airbox, RPW Thor pipe, Lloydz ECU, PC-III, Rivera Primo clutch spring, 31 tooth pulley w/Buell belt.
Half_crazy is offline   Reply With Quote Quick reply to this message
