Bolt in cam for stock 103" : V-Twin Forum: Harley Davidson Forums
Old 08-18-2012, 10:24 AM   #1 (permalink)
themachinist79 wants to know Dino or Syn?
I've got an '09 FLHTPI that I'm looking to just simply bolt a cam into. I don't need anything crazy...just the biggest I can stuff in there without having to worry about changing valvetrain or the like...just want to change it out in a couple hours...I do realize that I may have to get a tuner. Right now, all I've done is get the Stage 1 Flash(timing), a high-flow aircleaner, RB Racing header, and nightrider.com XiEDs(yes, they work wonderfully). I know I don't have all available ponies, but it sure runs a heck of a lot better than stock. Any opinions?
Potato, potato, potato, potato, potato, potato...Need I say more?
themachinist79 is offline   Reply With Quote Quick reply to this message
Old 08-19-2012, 02:13 AM   #2 (permalink)
sfmichael's Avatar
sfmichael wants to know Dino or Syn?
Sooo many good choices, you'd have to try to screw this up.
Andrews 48 or 54
Woods 222, 5-6, 555, 777
Cyclerama 575
Sykes SP232
I hope to put the CR575 in my 2010 96" but these are ALL really good choices, look at the specs and see where you want your power to come on. Cams with intake closing at under 40 degrees tend to make power the soonest or at lower RPMs. I'd stay with the cams in the 30's as far as intake closing for an otherwise stock engine (Stage 1).
sfmichael is offline   Reply With Quote Quick reply to this message
Old 08-19-2012, 03:43 AM   #3 (permalink)
semi-retired
FatBobRob's Avatar
FatBobRob wants to know Dino or Syn?
Don't rule out the Crane 1-6000 or a SE204. Both will run well w/o headwork and stock comp. What RB pipe do you have?
I can't means I won't!
FatBobRob is offline   Reply With Quote Quick reply to this message
Old 08-19-2012, 07:05 AM   #4 (permalink)
brownfoxx1 wants to know Dino or Syn?
check out the S&S 510 gear cam. this eliminates the cam shoe.
its the largest cam for the twin cam before you do any head work.
i really like it in my '09 tri-glide. while your in there
you might try a beisley oil spring. that would raise your idle oil pressure.
& if you have the $$ install a set of adj, pushrods
ALWAYS INSTALL NEW LIFTERS WITH A NEW CAM. old lifters track their wear onto the new cam.
brownfoxx1 is offline   Reply With Quote Quick reply to this message
Old 08-19-2012, 09:05 AM   #5 (permalink)
C-Cat wants to know Dino or Syn?
Woods new 222
124 ci. 07 Streetbob
107ci. 2011 RGC
C-Cat is offline   Reply With Quote Quick reply to this message
Old 08-19-2012, 10:05 AM   #6 (permalink)
Gearhead
2wheelrider's Avatar
2wheelrider wants to know Dino or Syn?
99 to 05 will take up to a .510 lift cam max. after 06 you can go to a .575 lift cam max.
2001 FLHTC 95ci Custom mtr hyd cam & 06up heads
welded btm & forged pistons to much to list. for sale.(SOLD)
2001 FXDXT (S&S SA 131ci motor)
2010 street glide..103ci 57 cams...fun and reliable...
2wheelrider is offline   Reply With Quote Quick reply to this message
Old 08-19-2012, 11:26 AM   #7 (permalink)
qtrracer's Avatar
qtrracer wants to know Dino or Syn?
Andrews 57, high lift version(.560") of the 37. If I was to be in your shoes I would just stop looking and put those in.
"You have to inspire yourself. I am my own role model. I want to be me." Vincent Lepak 2008
qtrracer is offline   Reply With Quote Quick reply to this message
Old 08-19-2012, 11:34 AM   #8 (permalink)
Axe Man
BVBOB's Avatar
Tman 555 torquester, great cam from bottom to top.
1982 FXRS
80 inch
Drag pipes
SU carb
Andrews A cam
2002 Ultra Classic
127 cubic inch
Rush Wrath
custom cams
152 hp 155 tq
2016 Ultra limited.
Old 08-19-2012, 11:38 AM   #9 (permalink)
djl
djl's Avatar
djl wants to know Dino or Syn?
'99-'04 will take up to .510" lift, maybe a bit more, just have to check for coil bind. Beehives introduced in '05 and max lift increased to .570", again, could be a bit higher, just have to check for coil bind.
djl is offline   Reply With Quote Quick reply to this message
