Mileage/reliability : V-Twin Forum: Harley Davidson Forums
Old 08-18-2012, 03:20 AM   #1 (permalink)
HDSB07 wants to know Dino or Syn?
Mileage/reliability
I know it will vary on many factors but in general what is the reliable life expectency of an engine as far as mileage/age?
HDSB07 is offline   Reply With Quote Quick reply to this message
Old 08-18-2012, 08:17 AM   #2 (permalink)
filterless's Avatar
filterless is reading this now saying WTF is this?
check the thread by pete1182 on the next page.
filterless is offline   Reply With Quote Quick reply to this message
Old 08-18-2012, 11:15 AM   #3 (permalink)
Bubba Neil wants to know Dino or Syn?
No reason why they can't do 100k fairly easy, some have done more.
Now some have failures due to cam chain tensioners coming apart and causing more problems, also the INA inner cam bearings can cause problems.
But major components, top end, bottom end, transmission etc, if maintained can go quite a while if the bike is maintained.
Bubba Neil is offline   Reply With Quote Quick reply to this message
Old 08-18-2012, 03:12 PM   #4 (permalink)
brother wants to know Dino or Syn?
I'd change the inner cam bearings and tensioners to the hydralic set up or it's the luck of the draw, which My inner bearings were starting to go at 32K and took out the cams, also the tensioners were bad.
brother is offline   Reply With Quote Quick reply to this message
Old 08-18-2012, 03:26 PM   #5 (permalink)
Michael Psycle is reading this now saying WTF is this?
My evo fxr now has about 102,000 on it and is running fine. No engine work needed as yet.
Michael Psycle is offline   Reply With Quote Quick reply to this message
Old 08-18-2012, 09:06 PM   #6 (permalink)
I have seen several EVO's with over a 100k on them with nothing more than oil changes.
Old 08-19-2012, 12:33 AM   #7 (permalink)
sfmichael's Avatar
sfmichael wants to know Dino or Syn?
Yup, should go 100K with some luck and some maintenance.
sfmichael is offline   Reply With Quote Quick reply to this message
Old 08-19-2012, 12:40 AM   #8 (permalink)
Sturg's Avatar
Sturg wants to know Dino or Syn?
I recently met a guy with a 05 UC with 202,000 miles on it, so with proper maintenance you can run it indefinitely.
Sent from my MB860 using Motorcycle.com Free App
Sturg is offline   Reply With Quote Quick reply to this message
