Dual runner throttle body : V-Twin Forum: Harley Davidson Forums
Old 06-15-2012, 03:19 AM   #1 (permalink)
aubeagle wants to know Dino or Syn?
Here goes my first post since joining a little bit ago. I have a Gerolamy Dual runner Tb that i bought one year ago its on my 04 dyna that is 88" but not for long. It seems to work pretty well now The motor has MCR heads and a S&S 510 with a propipe and Tmax with autotune if anything its a little on the big side now. Iam almost done with a 113 with mva heads and 10.5 pistons. My queston is anybody using one besides for me or can a member give the pros and cons of running this set up verses the tried and true single runner Tb. Thank you aubeagle
aubeagle is offline   Reply With Quote Quick reply to this message
Old 06-15-2012, 09:26 PM   #2 (permalink)
Gerolamy dual flow TB
I always have had to make my things a little unique from The Jones next door or done the street. Thats another reason for running it. My 04 FXDLI is still a 88' motor with S&S 510 and mcr se heads Propipe the big zippers air filter and of course the Dual runner tb Tmax auto tune. Also a chain converison and a final drive of 3.06 Now my buddy that i ride with has a 04 FXDWG with a 95' inch motor with 10.5 se pistons and mcr heads, Same propipe as mine 570 S&S Geardrive Tmax w/autotune that Zippers tuned. When we line em up whoever gets the jump is the one that stays out front. It seems to me that he could really benifit from some headwork as both sets are out of the box nothing done. Am i on the right track with that?
aubeagle
Old 06-15-2012, 09:48 PM   #3 (permalink)
guydoc77's Avatar
guydoc77 wants to know Dino or Syn?
The only "dual runner Throttle Body" that I am aware of is the older Magnetti Marelli systems. An '04 is Delphi. Therefore I suspect you are talking about the Air Cleaner and not the Throttle Body. As far as your question, there are some who run dual runner air cleaners but they are not that common that I've seen. Doesn't mean they are bad however. I have considered the current S&S product but it's quite expensive and I am not convinced it offers any improvement in flow. It's cool looking though.
2008 Road Glide
Phoenix Customs Bagger Brace
Glide Pro
Clearview windshield
107
CP flat tops
R&R Stage 3 heads, .030 gasket, 82cc chambers
Trued, welded, and balanced crank by Hyperformance
TMan 590 cams
SE AC
HPI 54mm TB
Supermeg with open cap and 15 discs
TTS tune by BVBob
2003 Indian Scout Deluxe
Aspen White (got it for my wife)
S&S "SuperStock" 88"
12" apes
Scary fast!
guydoc77 is offline   Reply With Quote Quick reply to this message
Old 06-15-2012, 10:05 PM   #4 (permalink)
Hello, I bought it from Gerolamy's websit. They make em for the different sized intake ports (twincam) and i think they will also do for the taller aftermarket cylinders. It uses all the factory sensors Tps, map ect. 50mm in size.
Old 06-16-2012, 03:39 AM   #5 (permalink)
guydoc77's Avatar
Interesting. New one on me.
2008 Road Glide
Glide Pro
107
CP flat tops
TMan 590 cams
SE AC
HPI 54mm TB
TTS tune by BVBob
12" apes
Scary fast!
Old 06-16-2012, 05:15 AM   #6 (permalink)
Money Pit's Avatar
Money Pit wants to know Dino or Syn?
Back before my 124" disintegrated, I too was looking at the Gerolamy and S&S Dual TB.
Seems like most people sided against the Dual TB but I never had the opportunity to experiment with either.
I remember forking out quite a bit of cash for a new DTT TCFI IID that nobody could tune either...
That thing is still sitting in the bottom of my tool chest.
Money Pit is offline   Reply With Quote Quick reply to this message
Old 06-16-2012, 03:26 PM   #7 (permalink)
The throttle shaft broke in the factory Tb and the dealer said they couldnt get just that part (?) So i went to the Indy that did the head and cam upgrade, He wanted a $150.00 for one he took off a customers bike and it was stripped of a sensors, They had a milk crate full of them!!!! Since i was going to do 113 SE build i bought the Gerolamy dual runner 50mm. Its been on the 88 incher since Now the 113 SE motor is almost done i just hope it will work for me. The MVA heads are going to Dan Vance Racing on 7/13 he said bring it and he will check it out for me. It will need to be opened up a bit to match the intake ports of the MVA heads. No luck yet of finding anybody else thats using one.
aubeagle
Old 12-04-2012, 05:26 AM   #8 (permalink)
torqueinc's Avatar
torqueinc wants to know Dino or Syn?
Any results from the BC throttle body ?
torqueinc is offline   Reply With Quote Quick reply to this message
Old 12-04-2012, 06:46 AM   #9 (permalink)
When i had my heads done i also had the dual runner there to be checked out. It did not flow very well. Both runners were necked down a good bit from the 50mm blades, When the man says porting it most likly wont do any good for the se113. I listened this time. I did the HPI 55mm. Runs very good Have a good day..
S.
04 FXDLI
SE113
Dan Vance
Ported MVA's
Crane 296-2
Woods lifters
SE Roller Rockers
HPI 55 tb
Marren 5.3
Injectors
VH Propipe
T/max
Old 12-04-2012, 07:15 AM   #10 (permalink)
The HPI unit for the MM system is a very nice unit and a works very well..
Old 12-04-2012, 09:04 AM   #11 (permalink)
torqueinc's Avatar
Steve
Not looking for a MM replacement I would like to run a dual runner intake,If i have to run something else than a BCG or S&S that is ok I suppose i could build something.
Old 12-04-2012, 09:14 AM   #12 (permalink)
SORRY I mis understood the post.. A person to talk with on the dual runner for performance on big engines with real testing is Mike Roland..
Old 12-04-2012, 02:05 PM   #13 (permalink)
Don Dorfman's Avatar
This is true IR
2x50 is too small for larger motors
Old 12-05-2012, 12:00 AM   #14 (permalink)
torqueinc's Avatar
Fully understand IR manifolds and the requirements
I bought a set of S&S 79 CC heads complete but disassembled and a 98 inch rotating assembly with some trick parts for $800
Want something to play with,thought this might be fun
Old 12-06-2012, 08:51 AM   #15 (permalink)
Axe Man
BVBOB's Avatar
The dual runner throttle bodies have one issue that should be mentioned, a vacuum source for the MAP sensor when running a Delphi injection setup, not a lot of info out there as to how a reliable reading could be taken from the MAP sensor, I have heard of tapping a port in both runners and using a T but have never seen it first hand, would be fun to play with on the dyno at any rate.
1982 FXRS
80 inch
Drag pipes
SU carb
Andrews A cam
2002 Ultra Classic
127 cubic inch
Rush Wrath
custom cams
152 hp 155 tq
2016 Ultra limited.
