Still blowing oil out the breathers - Page 2 : V-Twin Forum: Harley Davidson Forums
Old 05-29-2012, 08:57 AM   #16 (permalink)
not sober all the time
Uncle Salty is reading this now saying WTF is this? Uncle Salty is reading this now saying WTF is this?
You may find one locally at a tool house, Sears, etc. Online you will find many outlets selling them, Amazon, Jegs, Summit, Ebay, etc. Starting around $50 and up. Brands include Longacre, OTC, Snap-On, Proform, Moroso, etc. You can build one too, instructions online but you won't save a lot if you have to purchase all of the individual parts.
Uncle Salty is offline   Reply With Quote Quick reply to this message
Old 05-29-2012, 12:19 PM   #17 (permalink)
06roadglide wants to know Dino or Syn?
Originally Posted by Pikeslayer View Post
I wouldn't mind doing that leak down test. Anybody know where I can get a tester?
I got mine from Jegs. Don't know if autoparts store loan anything like that but if you dont want to buy one and cant find one close I'm not too far, 45311. Your more than welcome to use it.
06roadglide is offline   Reply With Quote Quick reply to this message
Old 05-29-2012, 11:30 PM   #18 (permalink)
Still the Same!
wurk_truk's Avatar
wurk_truk wants to know Dino or Syn?
I got one you can borrow if you wanna swing by Columbus.
120r
wurk_truk is offline   Reply With Quote Quick reply to this message
Old 05-30-2012, 05:13 PM   #19 (permalink)
Thread Ender
Pikeslayer's Avatar
Thanks guys! I may hit one of you up a little later to borrow it. I have to do some traveling in the near future, so I may not get back to this for a couple weeks. I'll keep you posted.
2007 Street Glide
Old 06-11-2012, 10:05 PM   #20 (permalink)
supermod's Avatar
supermod wants to know Dino or Syn?
Leak down tester
Ive used some that were commercially available and made my own-Im sure you will find poor ring seal-
supermod is offline   Reply With Quote Quick reply to this message
Old 09-19-2012, 08:20 AM   #21 (permalink)
Thread Ender
Pikeslayer's Avatar
Well it's getting close to the end of the riding season so I better figure out a plan for this oil puking problem. I'm pretty sure it is excessive blow-by. Guess I'll check leak down.
2007 Street Glide
Old 09-19-2012, 11:40 AM   #22 (permalink)
Livin' Free Indeed
AzFAL's Avatar
AzFAL wants to know Dino or Syn?
Please report on your leak check percentages. FYI I also had excessive oil consumption & blow-by until I made some cyl. changes. Are you getting any pinging with roll-ons? This could also be a symptom of oil getting past the rings & into the combustion chambers.
"All that is necessary for evil to triumph is for good men to do nothing" Edmund Burke
"Those who will not be governed by God will be ruled by tyrants" William Penn
2002 Dyna
124" S&S
10.8:1 cr
640G cam
45 Mikuni
Bassani Pro-Streets
DTT ign
AzFAL is offline   Reply With Quote Quick reply to this message
Old 09-19-2012, 04:01 PM   #23 (permalink)
djl
djl's Avatar
djl wants to know Dino or Syn?
There are single and dual gauge units;the video is showing a single gauge unit. It would appear to someone unfamiliar with leakdown testing that the single gauge units would be easier to operate. However, the single gauge units require particular attention to the inlet pressure, as each gauge will have its own requirement. If the inlet line pressure is too high or too low, the test results will not be accurate.
Some twin-gauge models also require a specific range of inlet pressure, which you read on the first gauge. The second gauge will read a percentage of cylinder leakage. Matco and OTC both make affordable and accurate leak down testers.
By the time you run around and pick up the parts to make the single gauge unit shown in the video, you will have spent half of what it would cost to purchase a solid twin guage unit. JMHO.
Leakdown past a valve should be confirmed by tapping the valve lightly, just to make sure it is fully seated. Everybody wants a 2% leakdown motor but that is unrealistic. Ring leakage of 8%-12% is "normal" and up to 15% is acceptable; if 20% or more, freshen up the top end. Variation from cylinder to cylnder of 5% is normal.
BTW, I run the ET Mini Crank Vents on my 107" and they work well. You cannot eliminate 100% of crank vent mist; rings have gaps. However, if you can maintain a vacuum in the crank case, you will minimize blowby to misting; not puking. That is assuming the top end is healthy.
djl is offline   Reply With Quote Quick reply to this message
Old 09-21-2012, 12:59 PM   #24 (permalink)
Don Dorfman's Avatar
I won't touch what is acceptable leak down, I do have an opinion however.
Fact is blow by will overwhelm the seperators and blow oil out the breathers regardless of design. The OEM breathers work fine except the plastic design used from 2002-2004 roughly.
Regarding rings and oil consumption, it is entirely possible and probable to have no cylinder problems, proper end gaps, decent compression checked and leak down and still use oil by the rings. Second ring is the critical factor.
Old 11-26-2012, 03:57 PM   #25 (permalink)
Thread Ender
Pikeslayer's Avatar
Performed the leak down test today. I got 35% on the rear and 55% on the front. This was using the cheap harbor freight unit. Was performed cold. Not sure what to think.
2007 Street Glide
Old 11-26-2012, 05:06 PM   #26 (permalink)
Where was the air going? Out the exhaust, breathers, throttle body?
Old 11-26-2012, 05:22 PM   #27 (permalink)
Premium octane member
TXCHOP's Avatar
How was test performed? Me thinks, the motor might have spun a bit. I use a ratchet strap on the rear brake in gear. With that blowby i dont think it would run well. Or the gauge sucks.
S&S T124
Old 11-26-2012, 06:49 PM   #28 (permalink)
Thread Ender
Pikeslayer's Avatar
Not sure where the air is going. I just wanted to get a rough idea how each cylinder looked. I am suspect as to the test procedure too. The instructions tell you to zero the gage by turning the regulator on the unit up until the "percent" gage reads "set". This results in about 10 psi being used. Difficult to get it to stay at TDC due to the valve train. You are supposed to try to pull all this off when its hot too. I'm starting to question the value of this test. My problem was intermittent, so what are the odds the conditions will all be there while I'm performing this test.
2007 Street Glide
Old 11-26-2012, 11:12 PM   #29 (permalink)
HighLiner wants to know Dino or Syn?
Don't know if that is the correct way. On my Mac Tools tester I set the inlet psi to 100 and read the leaked psi on the second guage. I use 100 psi because it's easier to do the math (i.e. 100 psi in, 90 on the second=10% leakage).
HighLiner is offline   Reply With Quote Quick reply to this message
Old 11-28-2012, 07:53 PM   #30 (permalink)
Thread Ender
Pikeslayer's Avatar
Well I think I'm just going to plan on tearing it down and honing it and re-ringing it. If I see something scarier when I get in there I'll deal with it then. About time for some new lifters, any recommendations?
2007 Street Glide
